Essential Wrench Sizes
/ Essential Wrench Sizes #1
Underdog57
W Michigan
LS R4041H
I just realized my Metric tool collection is very undersized. Is everything on these LS Tractors Metric? I am going to go buy some tools soon and would like all you LS Tractor Pro's to put together the essential wrench & socket sizes I need for basic service & bolt tightening. I have assorted wrenches up to 24mm & sockets up to 18mm. If someone could post a list it would be big help to me. Thanks for all the great info.
PS. 15 hours & counting!
/ Essential Wrench Sizes #2
Good idea ... of course, these tractors are so reliable, you'll only need the tools necessary to keep your loader bolts tight and your filters/fluids changed.
Yup, I just read the thread about loose loader bolts!!!
/ Essential Wrench Sizes #4
Don't forget to pick up some metric pliers and hammers, too.
Bruce
/ Essential Wrench Sizes #5
What I have found in my shop that mostly all bolts are metric. The loader bolts you can get away with a 7/8. The only thing I have seen that is bigger than what you said you have is the drain plugs on the hyd sump (transmission) they are 27mm. What I like most about LS is most of the bolts on the tractors are 19mm, 16mm, 12mm, and 10mm. Also on the sub frame backhoe the bolts for is are 32mm. Plus a deep 32mm would make things easier if you have the backhoe attachment for checking the mounting bolts on the sub frame. The rest of the bolts on the tractor for the brackets on the sub frame are 19mm and 22mm. I hope this helped ya Underdog.
/ Essential Wrench Sizes #6
For my old bush hog, I needed a 1 1/2" socket (37 mm). Think for this new bush hog I may have to get a bigger socket for the bolts holding its blades in place.
Get yourself a 5 or 6 ft piece of metal pipe that'll go over your big socket drive handle to torque bolts that need 450 ft-lb or thereabouts. A full push on a 5 ft handle till the nut won't tighten any more is probably close enough to 450 ft-lb. Works for me anyway.
Ralph
/ Essential Wrench Sizes #7
450 ft-lbs= 2 Grunts.
/ Essential Wrench Sizes #8
I just realized my Metric tool collection is very undersized...
Why I keep a metric adjustable wrench handy...!
...likewise with a set of metric vise-grips...!
Thanks a bunch, now I'll do an inventory on my tool boxes and I'll know what I need to buy along with the Metric pliers, metric adjustable wrench, and metric hammers!! :laughing:
/ Essential Wrench Sizes #10
I went to HF and they have the jumbo set but it was $50 so I checked at Home Depot and they had both the 27 and the 32mm wrenches individually for $8 and $12 respectively. I bought them so I hope that fills the need.
/ Essential Wrench Sizes #11
a 18" pipe wrench will loosen those "cranky" bolts.
Its especially handy when shoved into a piece of 1-1/2" sch. 40 about 3' long.
Try that before you go spending a bundle on those "weird" metric things.
Oh yea...I don't own an LS tractor.
I do own an LG television however....
/ Essential Wrench Sizes #12
When I got my first tractor I saw right off that the sockets and wrenches I had were not large enough. Harbor Freight had a sale on 3/4" drive sockets (7/8-2") (19mm-50mm) in SAE and Metric, ratchet, breaker bar and extension. I was in Africa at the time, so I had the wife pick up a set of both. I have used t from smallest to largest, but not everything in between. I use them on my 650 ft. pound impact gun with no damage. I don't think they were but $29.95 and have a life time guarantee. The keeper ball that holds the socket on popped out of the ratchet when I rapped it on my disc to dislodge the attached socket and they gave me a new one, no questions asked. They may not be Snap-on quality, but with a lifetime warranty, who cares if something breaks. I have put a 4 foot cheater on the breaker bar tightening a lift pin and it held as much as my 240 pounds could put on it.
Edit: I also bought their large wrench set @ HF from 1" up to 2" size IIRC. I now have sockets and wrenches from 1/4"-2" and in metric size 4mm-50mm to match. I also picked up the new thru the socket set for the smaller bolts. This eliminate the long bolt that you cant tighten with a socket as the bolt will just go up thru the socket just like using a boxed in wrench. They come in handy sometimes when needed, but mostly just stay in the tool box. Nothing worse than needing a wrench or other gadget that you don't have and have to run out to NAPA to find it. I had to do that when I changed my oil that required a 19mm Hex wrench. I didn't have anything nearly that large, but I do now.
R4041H update. 19 hours. Tightened loader bolts (22mm) with my new tools today. About half of the bolts needed a 1/2 turn and a couple needed a full turn. The bolts on the lower arms that go back to rear axle were really loose.. Thanks to you guys at TBN for clueing me in.
The tractor has a small coolant leak near the water pump bolts, tried tightening bolts but still leaks when engine is cold, when engine warms it doesn't leak. I think gasket might be bad. Dealer is picking tractor up Wednesday to repair, has anybody else heard of this problem on LS tractors? Other than the leak everything is great. I love my Tractor so far and my wife thinks my tractor is sexy. ;)
/ Essential Wrench Sizes #14
That is the first time I've heard of it ... could it be that the house was over tightened and cracked?
Well I guess that's what warranties are for. It will be a good test for how my dealer takes care of me.
Dealer (Robinson Equipment, Lakeview, MI) picked up tractor (23.5 hrs) @ 10:00 today to fix coolant leak, the thermostat housing was cracked. They delivered it back to me @ 3:30 PM same day!! Awesome service.:)
/ Essential Wrench Sizes #17
Does anyone know if everything is metric? Like the hydro hose fittings, Grease zerks, any Allen Head bolts, torx?
Beyond normal stuff every gear head should already have, are there any tractor specific tools one should have on hand?
2019 Ford Transit 350 Police Transport Van (A61573)
2019 Ford Transit...
Caterpillar C Series Backhoe Service and Parts Manuals (A63117)
Caterpillar C...
2026 Stout TB-76 Tri-Blade Brush Cutter (A64047)
2026 Stout TB-76...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A59904)
2017 FREIGHTLINER...
iDrive TDS-2010H...
Timberjack 608B FellaBuncher (A62679)
Timberjack 608B...
