Cutting down some trees and have a question
   / Cutting down some trees and have a question #1
kubota4me
USA
An orange one
I am cutting down some trees on one border of my land. I have the boundary pins located on both ends. The trees lie in the middle and when I am at one end I can't see through the trees to the other end(boundary pin). I have thought about having the wife wear orange vest and stand at one pin or have her shine a flashlight towards the other pin. I don't want to cut down any of the trees on the neighbors property. Is there a way that I can get in the general vicinity and gradually take out enough trees to clearly see the other boundary without enlisting the expense of a surveyor? Google earth perhaps or a portable consumer grade gps?
   / Cutting down some trees and have a question #2
It would be a good idea to consult your neighbor to see whether he/she agrees with your determination of the boundary line, regardless of how you make that determination (i.e., without additional surveying).
Steve
   / Cutting down some trees and have a question #3
You could use a r**** scope and a field support and sight down the line with your field support on the property pin and helper holding a vertical stake on the opposite pin. If you cant see it then the trees are on your side. Caution, make sure the gun isn't loaded or you could just use the scope and hold by hand.
   / Cutting down some trees and have a question #4
If you can, measure out 10-20 feet perpendicular from the pins at each end. Establish a clear line of site along that line. Using two people, you should be able to put some temporary posts in on that line. Then you have a straight line to measure towards the boundary from, a known distance.
GPS is not accurate enough. You would need a good Google Earth image to work from. I don't have that, perhaps you do.
   / Cutting down some trees and have a question #5
Let the neighbor know what you are doing first if possible. How far apart are the pins? You could use a plumb bob and a hand held or tripod mounted laser, or measure off the property pins a set number of feet on both ends where you can easily see both points and set your line, then measure off that line back to the property boundary using the laser.
   / Cutting down some trees and have a question #6
Most landowners are very appreciative of a considerate neighbor. You might find the jerk in the bunch, but you might also end up with an excellent relationship with your neighbor and that is priceless... I have gained plenty of hunting opportunities by being respectful...
   / Cutting down some trees and have a question #7
Some interesting legal stuff about trees and boundaries in Maine.
The fruit growing on a neighbor's tree that hangs over the boundary, or falls on your side of the boundary, belongs to the neighbor.
A tree on the boundary line can only be removed with consent of all owners.
Branches or limbs from a neighbor's tree that extend across the boundary can be trimmed back to the property line only. Your trimming may not damage or destroy the tree. You may be held liable for damage or death of the tree up to three times its value. The trimmed wood belongs to the neighbor.
   / Cutting down some trees and have a question #8
Steve
Great advice here.You could be stung with a big bill if you are wrong.
   / Cutting down some trees and have a question #9
Some states the line trees are property of both land owners. And when the neighbor brings in a logging crew they can't cut those unless they pay you half or you agree. Plus you can acuaully hold them off the line by x feet if you choose. Like I said that is some states so I would check.
   / Cutting down some trees and have a question #10
If you are sure of the location of the two boundary stakes then Google Earth can be quite helpful. Zoom in as close as possible and put a pushpin at the location of the stakes.
Then zoom out and connect the two pushpins with a line. Save the changes.
Then print out a picture of the pushpins w/line so that it fills up most of the 8 1/2 by 11" piece of paper. That should show the exact location of the trees relative to the property line. Note the date of the Google Earth photo (it is at the bottom of the page).
Finally, share the picture with the neighbor to get agreement of the location of the trees and what you intend to do with them. If possible, get the agreement in writing. Then you'll be good to go.
I did this to cut a path through my eucalyptus orchards from my Internet dish to the transmission tower. Worked great! Showed each individual tree to cut down to clear the path.
Tafe 45DI (A53317)
Tafe 45DI (A53317)
SKID STEER ATTACHMENT MULCHER (A58214)
SKID STEER...
Case 870 Agri King Loader Tractor (A59814)
Case 870 Agri King...
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
1992 Norris Long Basket Trailer (A60460)
1992 Norris Long...
2007 Ford F-350 9ft. Stakebody Flatbed Truck (A55852)
2007 Ford F-350...
