BX2660 Constantly Gels
/ BX2660 Constantly Gels #1
acoya
Help, am i missing something obvious? My bx2660 constantly gels even at relatively mild temps, its 25F today and the thing is gelled solid. I mix my anti gel additive into my fuel, Ive tried howes lubriator and power services arctic diesel supplement. Ive mixed them at above the recommended ratio and at the suggested ratio all with the same results. It always gels at the filter under the tractor, and on a bx2660 thats no fun to crawl under and thaw in snow. Any suggestions??
Joe
/ BX2660 Constantly Gels #2
Have you ever had any problems with water in the fuel system? You could also try putting 1/2 gallon of gasoline in a full tank(6.6 gal cap) of diesel
Nope, never any water issues. Its just cold, and not super cold even, as soon as it drops below 30 the tractor is likely to freeze. Its 25 right now, i started it, it ran for about 1 minute, then seized. Thats with fuel that i mixed with howes at a higher rate and even let sit inside for a day to make sure it mixed at a warm temperature. I seriously hate this tractor.
/ BX2660 Constantly Gels #4
DO NOT put gasoline in your diesel unless you want to trash the injection pump! Cut the fuel with 1/3 to 1/2 Kerosene.
/ BX2660 Constantly Gels #5
What does hating tractor have to do with gelled fuel. Wrong or improperly treated fuel can/will gel in any model/brand tractor
well, having a tractor that gels constantly is amazingly frustrating when you live in a winter climate. If i am improperly treating the fuel that would be helpful to know. Im not putting gas in it, ive tried kerosene too, it still gels.
/ BX2660 Constantly Gels #7
wow, that sucks. I started mine in -4F yesterday, and nothing gelled. I use winter blend from gas station and dont add anything.
I believe the winter blends have some percentage of kerosene in them already. Ive been running tractors for 17 years now in north idaho and have NEVER had a gelled tank. It has to be the fuel your getting. have you tried winter blends from other stations. If you have service stations that cater to large semi trucks..all the better.
/ BX2660 Constantly Gels #8
Volkswagen stated in their owners manual to add gasoline to diesel in below freezing temps. 18 wheeler drivers also do it. Have you ever personally seen an inj pump ruined from adding 10% or less gasoline to diesel in cold weather?? I'll bet not. I've even run a diesel pickup on straight jet fuel with no ill affects.
Yes, ive tried 3 local stations, with no different results the current one is from the station that doubles as a truck stop, tons of big trucks fuel up there.
/ BX2660 Constantly Gels #10
weird.... i have no idea. Have you ever tried NOT adding any fuel treatment or gel treatment. When living in Montana years ago (-60F) i thought id add more than 50:50 mix of antifreeze for better protection. WRONG. that actually increased the freezing point of the water. Who knew.
/ BX2660 Constantly Gels #11
Have you changed the filter, there maybe water in it. I change the filters on gelled engines and add power service 911 to the filter and the fuel tank.
I've never mixed power service with how's, maybe they dont like each other, you may want to drain the tank, change the filter and start over.
Dave
/ BX2660 Constantly Gels #12
Dave
/ BX2660 Constantly Gels #13
Dave
Good advice I'd also check the electric transfer pump.
/ BX2660 Constantly Gels #14
Diesel fuel does not gel at 25F.Unless you're getting a bad bio-diesel blend mandated by your state since all your local sources yield the same results,water in the fuel system seems like the only logical culprit.
You state that basically,once the temp falls below freezing,your tractor stops running.Tractor sitting outside often,low fuel level during temperature variations,one bad can of water-laden fuel can all introduce water into your fuel system.
Really,the tank needs to be drained and the fuel left to separate out and most likely you will find water at the bottom of the container.
Good Luck! and post back.
/ BX2660 Constantly Gels #15
You got water! Water freezes before diesel gels. Get some Redline diesel fuel catalyst and change your fuel filter. If need be drain your fuel tank; water settles to the bottom and gets drawn off first, thus clogging the filter and preventing engine start.
It's NOT your tractor, it IS the fuel system contamination and need for a fresh filter.
Post back results.
And, what state are you in? And your tractor too....
/ BX2660 Constantly Gels #16
Wonder if you have a bacteria problem? I use both the power services and a stabil additive.
/ BX2660 Constantly Gels #17
I agree. dont put gas in the BX. use kerosene if needed to keep fuel from gelling if no additives used. The BX engine is too small to handle gas/diesel mix like big trucks can. I think you need to change BOTH filters on BX and filter all diesel before pouring in the BX tank. Apparently the fuel you are putting in might be contaminated already with either water or algae. If you have alot of it stored, I'd get a sample tested to be sure.
/ BX2660 Constantly Gels #18
I totally agree. I have no issues in my area with straight #2 and it gets way below 25 degrees. On some backup standby generators I used to run 25% #1 and 75% #2 just to thin it a bit but any thinning that way reduces BTU output of the fuel meaning less power.
If you had a fuel gelling problem with #2 at 25 degrees, every diesel owner in the Pacific Northwest would go nowhere in the winter.
2015 Chevrolet Silverado Flatbed Truck, VIN # 1GB4KZC87FF627659 (A65563)
2015 Chevrolet...
New/Unused CFG Industrial MH12RX Mini Excavator (A65583)
New/Unused CFG...
Continental Cargo 24' Enclosed Trailer (A66285)
Continental Cargo...
2016 Audi A6 AWD Sedan (A64557)
2016 Audi A6 AWD...
🚜 2022 Mahindra 1635 HST Tractor Package – ONLY 36 HOURS – FULL SETUP READY TO WORK!
🚜 2022 Mahindra...
100-gallon L-shaped Portable Fuel Tank (A66408)
100-gallon...
