the old grind
Super Member
- Joined
- Jul 21, 2012
- Messages
- 5,308
- Location
- Mid-Michigan
- Tractor
- NH T-1520 HST, NH TC33DA HST, Case DX26 HST, .Terramite T5C, . NH L785
IIRC some injectors are tested by raising a pressure (high, btw .. bench test) to a pressure threshold above which they'd 'pop open', and apparently at the right time as designed. Adjustment is by shimming a spring and re-testing. Not that a Kubo's are similar, or that checking them thus would be any shortcut to finding the problem, but the symptoms still don't add up to me. :mur:
So, if one injector is acting up can its individual timing then be off by firing early or late? (factory defect, early demise) Power isn't too shy of spec (not -10%) but I might expect smoking from a cylinder that shot more or shot out of sync. Could any cylinder(s) be smoking because it/they are carrying others? I know these ideas are kinda 'out there' but balance shaft or no I'd think vibration would be amplified if so, and shouldn't o'all timing only affect o'all power? (Seems retarding can up the oomph & advancing trades that for economy.) What's all that shake & smoke about?? Smoothest runners I've seen have smoked the least, too.
Fred, that any of us wouldn't go ahead with the turbo means zilch with your obvious potential and the support available here if you need it. Can't wait to hear more. :thumbsup:
