Ford 1700 Tractor
/ Ford 1700 Tractor #1
tjf78
NSW Australia
Kioti / Daedong
Hi Everyone
I am after a bit of advice
I am looking at buying a Ford 1700 tractor, it however has a sticking clutch.
Am I crazy for even considering it or is the fix not to hard or expensive?
Thanks
TOm
/ Ford 1700 Tractor #2
Although I have not changed clutch on 1700 but i have done it on several front wheel dive vehicle. If you do not have a loader then I consider it easier than doing it on a car. The whole clutch assembly can easily be had fro Fleabay for under $200. If otherwise the rig is in good shape then it is Perfectly logical to do the work. Give some info on price, # of hrs and other pertinent. may be You can get a good price because of sticky clutch, spend under $300 and end up coming pretty good at the end. Anty pics of the rig ?
JC,
/ Ford 1700 Tractor
JC,
There you go I might look into it further. It looks to be in good condition.
Cheers
Tom
/ Ford 1700 Tractor #4
Cheers
Tom
Not bad Tom, loader and ROPS , two rare commodities for old 1700. It kooks good , how much are they asking? does the lift and loader work?
JC,
/ Ford 1700 Tractor
JC,
Apparently everything works other than the clutch sticking and the lights (apparently the wiring )
He is asking $5200 which looking at prices of comparable kubota's here in Aus seems good as long as the repairs are not too expensive.
Cheers
Tom
/ Ford 1700 Tractor #6
Tom,
$5200 is steep but loader brings up the price. Let him know that a dealer work on the clutch will be about 1200-1500 and at least you want that subtracted from price. $3500 to $4000 seems to be a fair price. You can get the clutch done if you are mechanically inclined without much difficulty under $250 and of course some sweat equity.
JC,
How many hrs does it have?
/ Ford 1700 Tractor #7
My "2 cents worth" is that the 1983 Ford 1700 I have is a phenomenal tractor. So reliable, strong, sturdy. If you can get it at a good price - you won't be disappointed.
Good luck,
Jay
/ Ford 1700 Tractor #8
I purchased a 1700 in 2006 and the clutch was stuck from lack of use. I backed it up to a large tree and started it and the clutch popped loose and has worked since. I love this 1700, I have the front loader and a 5 foot rear blade and a few other implements. Mine is a 4 X 4 and is just a great little tractor. It has hauled dirt from a pond we had dug by a caterpiller, to neighbors trucks until the dirt was gone. It is a 1/4 acre pond 17 feet deep so was a lot of dirt. I have used the blade to clear snow from driveway for past 7 years. The only maintenance has been a new fuel filter every 6 months and a change of the hydraulic fluids annually. I only have 1900 hours on mine. Goes anywhere and hauls most anything.
/ Ford 1700 Tractor #9
By the way, if clutch can be un-stuck, I would not sell mine for $5200, but again mine is a 4 X 4.
OUTBOARD ENGINE STANDS (A66738)
OUTBOARD ENGINE...
2012 KENWORTH TRIAXLE BODY LOAD (A67714)
2012 KENWORTH...
2021 Bobcat T66 Compact Track Loader Skid Steer (A66734)
2021 Bobcat T66...
CASE  721F WHEEL LOADER (INOPERABLE) (A67714)
CASE 721F WHEEL...
PALLET OF TRASH PUMPS (A68842)
PALLET OF TRASH...
CATERPILLAR PAVER (A65053)
CATERPILLAR PAVER...
