mobile application
/ mobile application #2
I had the iPad app and it lost functionality after it updated. I connect via Safari on the iPad rather than the app.
/ mobile application #3
mobile app for kindle i cant find one and search for"app" strikes out.
If your speaking of the new Kindle fire. I understand it has to be rooted in order to run Android apps other than the media apps they want you to use. It would be like jailbraking the iOS. Pity it won't run Google apps. But that's a marketing tactic. -kid
/ mobile application #5
Tapatalk works for my other forums but I couldn't get it to hook up with TBN
Tapatalk
The new Google pad looks like the way to go. I'm just a bit Leary though. Google knows more about us than the CIA already.
Bump is one available yet I had knee surgery and can't get to my computer.
Will tractorbynet work on tapatalk?
TOM
/ mobile application #7
I use the TBN app in my android phone, don't think ive really ever logged on TBN with computer.
Here is an up date there is a way to add apps (I've done 2 so so far) on kindle fire hd.
You have to have android phone or have source for the app (xxxx.APK file)you want.
and a computer and cables to move the files from phone to kindle
Down load es file explore app to the phone and to kindle fire.
link to es file explorer
down load the app you want to phone and make sure it works.
On phone go in to es file explorer
menu key
app manager
user apps
select app you want to move to fire (it will be highlighted)
on soft keys at bottom select back up
Then connect computer to phone navigate to backups on phone.
Copy file to your computer (remember were you put it)
Unhook phone hook up kindle
Go to file es file explorer and back up any app the same as on phone
(this will make back up directory's)
On computer navigate to app that you saved to it and copy and paste it to back up folder on
Unhook kindle
On kindle go to es file explorer and navigate to backup/apps and click on app file you just put there it should pop up install or re install, say ok and let it install
log in to TBN app and give it a whirl!
Tom
/ mobile application #10
Here is an up date there is a way to add apps (I've done 2 so so far) on kindle fire hd. You have to have android phone or have source for the app (xxxx.APK file)you want. and a computer and cables to move the files from phone to kindle Down load es file explore app to the phone and to kindle fire. link to es file explorer down load the app you want to phone and make sure it works. <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=348657"/> On phone go in to es file explorer menu key app manager user apps <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=348658"/> select app you want to move to fire (it will be highlighted) on soft keys at bottom select back up Then connect computer to phone navigate to backups on phone. <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=348659"/> Copy file to your computer (remember were you put it) Unhook phone hook up kindle Go to file es file explorer and back up any app the same as on phone (this will make back up directory's) On computer navigate to app that you saved to it and copy and paste it to back up folder on <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=348660"/> Unhook kindle On kindle go to es file explorer and navigate to backup/apps and click on app file you just put there it should pop up install or re install, say ok and let it install log in to TBN app and give it a whirl! Tom
Is there a way to get the .apk file without an android phone? I have a kindle fire but no other android devices.
Chuck
Chuck
Chuck
Chuck
I can email it but it has to be external to TBN if needed
tom
2016 Chevrolet Silverado 1500 Pickup Truck, VIN # 1GCNKNEC1GZ163679 (A65563)
2016 Chevrolet...
2012 CAT D60-6 GENERATOR (A67714)
2012 CAT D60-6...
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
2007 HEIL TRAILER (A67714)
2007 HEIL TRAILER...
Tropic Trailer 18ft T/A Flatbed Equipment Trailer (A64553)
Tropic Trailer...
More Info coming soon (A64557)
More Info coming...
