STAINLESS STEEL Loader Pins
/ STAINLESS STEEL Loader Pins #1
massey184ferguson
Atlantic Canada
Massey Ferguson 184-4
Any Ideas as to getting a set of stainless pins made for snow pusher for anti wear , rust and strength properties? They'd be 1 1/4" in diameter. Already have them-got them for free
/ STAINLESS STEEL Loader Pins #6
Forget the stainless. There are far stronger and far more wear resistant options out there than stainless. And if you keep things greased properly, rust isnt a concern, so no need for stainless.
Call a local machine shop or steel supplier and see what they carry and suggest to use.
/ STAINLESS STEEL Loader Pins #7
The reason pins are not stainless is because you want the pins to wear, rather than egg out the holes. Much easier to replace a pin than repair egg shaped holes. Giv it some thought.
/ STAINLESS STEEL Loader Pins #8
Titanium..........................
/ STAINLESS STEEL Loader Pins #9
Great point.
/ STAINLESS STEEL Loader Pins #10
I needed a tapered pin so I could more easily align the ripper and bucket when I switch them out on my back hoe. I just measured the diameter of the factory pin and went to a metal shop to buy the right length piece of mild steel round stock which was then tapered. Works fine. Spray it with PBblaster if you want to keep the ends rust free but the business part of the pin will stay clean if greased.
/ STAINLESS STEEL Loader Pins #11
It is awfully confusing with 2 of the same thread going in two different areas of the forum.
/ STAINLESS STEEL Loader Pins #12
Confusing and unnecessary.
Sorry boys. Posted it and it never came up then it reappeared again.
/ STAINLESS STEEL Loader Pins #14
My new phone does the same thing now. It will come up as a error, and then it goes through. Then when it does go through IT DONT COME UP! UUUUUUGH!
/ STAINLESS STEEL Loader Pins #15
When I post with my phone, sometimes it seems to not go through. But, if I back out to the thread that I was trying to post to and hit 'refresh' from the menu, my post will show up.
New/Unused Deluxe Massage Chair (A65583)
New/Unused Deluxe...
2013 Ford F-650 Ext. Cab Chipper Truck (A64194)
2013 Ford F-650...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2018 CATERPILLAR CP56B PADFOOT ROLLER (A65053)
2018 CATERPILLAR...
2025 Mower King SSVR72 Hydraulic Vibratory Roller Skid Steer Attachment (A64553)
2025 Mower King...
2023 Schulte FX-318 Flex-wing Rotary Mower (A66285)
2023 Schulte...
