sixdogs
Super Star Member
- Joined
- Dec 8, 2007
- Messages
- 13,790
- Location
- Ohio
- Tractor
- Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
30* and cloudy. Could see stars in the sky when I got up, now a big bank of heavy clouds is moving through. Supposed to be a sunny day, high of 38*.
Made good progress working on a boundary line yesterday. I knew where the pins are but not the line between them. I found a line of old, faded blazes that the leaves keep hidden in the summer and flagged those trees. The remainder of that boundary is not blazed but there is some old barbed wire fence noted on the survey for part of it. Without a metal detector, that is hard to find under 2" of slushy snow. That will be a project for next spring after snow melt.
Hope you have a good day, and stay warm if you are in the storm path.
For border definition, get an aerial soil conservation map (Extension Agent or Soil and Water people) and look at it with those 3-D glasses to identify the corner trees and anything in between that might be helpful. Then get a pair of binoculars with a built in compass. Stand in one corner, aim in the direction of the line with the binocs and have a secondary helper find the line trees. Much easier this way.
On seeing stars, nothing beats being outside at night when it's 25 below. The stars are like diamonds and so spectacular it's not possible to describe them to others that haven't seen it for themselves. You can also look out the window of a dark room but it's not quite the same.
I used to sit up to all hours just looking at the stars on a cold night. Cold night means clear skies.
