jd 5065e or kubota m7040suhd please help decide
   / jd 5065e or kubota m7040suhd please help decide #11
I have the prior model of the 5065E which is the 5303. I have been pleased with mine. It is a 2008 and to my knowledge is almost identical if not. I pull a 8' 3pt disc harrow and most other implements are 6' stuff. No problems with any of it. Good luck!
Thank you! And am glad to see your pleased with yours how many hours do you have on ur tractor
   / jd 5065e or kubota m7040suhd please help decide #13
Believe I am around 625 hrs now. I bought used with less than 300 hrs if I remember correctly. You can spend more money for more features, but compared to what I grew up using these models are fancy to me and I like the simple design. I expect to have many years and hours service out of this tractor.
Yeh can't afford anymore options such as power reverser etc.. without dropping size. Thanks for the info and I like the simpleness of the tractor also.
   / jd 5065e or kubota m7040suhd please help decide #15
I would love to have that Reverser transmission. Of all options available, including cab, that is the one I would add first. Over length of ownership and probably financing too, it is a small price to pay with long lasting benefit. I may one day decide to update to one, but not any time soon.
   / jd 5065e or kubota m7040suhd please help decide #16
make sure you drive those things. the difference between a 9x3 gear and a 8x8 hyd shuttle are night and day.
   / jd 5065e or kubota m7040suhd please help decide #17
I agree, especially the shuttle for loader work and 4 speeds in each range haying.
My uncle has a little bit older 5xxx and the 9x3 is my biggest complaint.
   / jd 5065e or kubota m7040suhd please help decide #18
If was purchasing new, the Reverser would be a must have. I like the idea of having the same forward and reverse travel speed. It is not ideal in my opinion on the 9/3. The reverse on B range is a touch too fast for my preference.
   / jd 5065e or kubota m7040suhd please help decide #19
Amen Buddy. I traded a sync-shuttle for a hyd shuttle and would never won't to go back to pushing clutch pedal down to change direction of travel while loading/unloading rd bales.
Will have to see how big my christmas stocking is but agree would be nice feature.will try to find out extra cost and keep u posted thanks for all the input.
UNUSED RAYTREE RMBD72 - 72" HYD DRUM MULCHER (A54757)
UNUSED RAYTREE...
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
2017 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A54607)
2017 FREIGHTLINER...
SCAN FOR HAULING AND FINANCING INFORMATION (A52706)
SCAN FOR HAULING...
2007 Sterling Acterra Dump Truck (A51691)
2007 Sterling...
2013 Infiniti M37 Sedan (A55758)
2013 Infiniti M37...
