3320 range shifter warning
/ 3320 range shifter warning #1
jdjllee
Member
I was pretty busy mixing concrete with a gas powered mixer, backing away from mixer with a loader full of concrete, I turned about quickly to check the path behind me. When I turned back to facing forward, my forward/reverse foot controls had gone limp, inoperative. I was on a slight grade that led to a steeper bank, then woods. , the tractor started rolling backward. I fumbled with the foot controls, not believing they'd gone limp. The tractor rolled backward over the bank before I could even think to hit the brakes. I guess I should have thought BRAKES! first, but you know, I hardly ever use the brakes on a hydro tractor. It all happened pretty quick. Long story short, I got to the brakes, just before crashing into the woods, and lucky did not flip the tractor. When I had turned to check behind the tractor, my elbow, with heavy coat on, flipped the range shifter to neutral, but I did not know it. I notice now that range shifter sits up pretty tall on the seat. It's an easy thing to inadvertently shift that to neutral. Be careful out there guys. **** happens.
/ 3320 range shifter warning #2
Glad you were not hurt. This can be a potential problem on many of the newer JD tractors. I know the lever on my 2720 is always getting in the way. I wonder why JD thinks the range selectors need to have long bat handles? Other than moving them to/from neutral to start the lever doesn't see much action.
/ 3320 range shifter warning #3
I cut about 6 inches off mine, it was always in the way when getting in or out of the cab. It is still long enough to easily shift back & forth.
/ 3320 range shifter warning #4
That's a good idea, BIG.
My 1st Kubota would do what happened to the OP, and I would suddenly be in neutral.
On my current tractor, the range shift in LOW is in the way of my leg getting on and off.
It definitely needs to lose a couple of inches of length. Fortunately (?) it is hard to shift,
so accidental neutrals have never happened.
Vegetable Sprayer (A60462)
Vegetable Sprayer...
SAYLOR-BEALL 200 GALLON AIR COMPRESSOR (A62131)
SAYLOR-BEALL 200...
CASE TR310B SKID STEER (A62129)
CASE TR310B SKID...
30 Yard Roll Off Dumpster (A61165)
30 Yard Roll Off...
UNUSED KJ 33'X25' DBL GARAGE STEEL BARN SHED (A62131)
UNUSED KJ 33'X25'...
1995 Landoll 55 Ton Trailer (A60352)
1995 Landoll 55...
