Hydaulics
/ Hydaulics #1
Timber man
Ontario
Kubota
3 point hitch on my kubota model m7500dt working fine until I hooked up my snow blower with hadraulic chute.Now 3 point hitch and chute won't work .Help.
/ Hydaulics #2
:welcome:
I don't know your model and I don't do much with equipment on my 3ph but could your blower be too heavy for your rig? I'd disconnect then try the 3ph again to see if it works. Maybe you didn't connect just right - I understand some pto's have to be just so. Good luck and be sure to post your outcome/fix.
KW
/ Hydaulics #3
Explain how you connected the snow blower.
/ Hydaulics
Thanks I solved the problem,the change of cold weather froze the filter so I warmed it up and it started working.
/ Hydaulics #5
If your filter froze, doesn't that indicate water in the fluid?
Perhaps you should change to a fluid better suited to your climate.
/ Hydaulics #6
x2. use the cold climate fluid all year long
2005 CASE 580 SUPER M SERIES 2 BACKHOE (A62129)
2005 CASE 580...
New/Unused CFG Industrial H15R Mini Excavator (A65579)
New/Unused CFG...
SHOP BUILT TRI-AXLE LOWBOY TRAILER (A63291)
SHOP BUILT...
2015 John Deere CX15 (A64126)
2015 John Deere...
2019 Komatsu WA380-8 Articulating Wheel Loader (A64194)
2019 Komatsu...
2023 Bobcat L28 (A64126)
2023 Bobcat L28...
