1952 Ford 8N 302 v8 conversion
   / 1952 Ford 8N 302 v8 conversion #41
What I see as a potential problem is getting the year end hopping and breaking an axle or snapping something in one of the trannies.
Save yourself the aggravation and don't do that.
I wasn't too clear on that. I do not plan on making the rear end hop because of the danger of snapping an axle or part in one of the trannies.
   / 1952 Ford 8N 302 v8 conversion #43
You got it guys, it is for the novelty and because I want a hot rod (tractor). Parades, snow plow the driveway, pull a grader on our 3/4 mile driveway, no real horsing.
And the sound! Anyone else love the sound of a V8?
Yes i do! and I really can't give you a hard time because i have done a few car conversions ,
a Pontiac 455 punched .030 over to 462 cu in a 1984 Mazda RX7- still have it but haven't done any body or interior work yet, but with the 200-4R and lock up converter it is a blast to drive 100_0031.jpg
this engine is out of the car due to a wiped cam lobe at the moment but I put a stock 1969 GTO 400 in it for now... GO conversions :thumbsup:
Neat, do you have a thread on your car? If not you should start one. Where do people put car conversion threads?
a Pontiac 455 punched .030 over to 462 cu in a 1984 Mazda RX7- still have it but haven't done any body or interior work yet, but with the 200-4R and lock up converter it is a blast to drive View attachment 346799
   / 1952 Ford 8N 302 v8 conversion #45
I put a 250 cid chevy 6 in a XJ6 jag, was pretty easy. Long time ago no pics.
   / 1952 Ford 8N 302 v8 conversion #46
Keeping with the Ford theme......and conversions.......here is mine but sorry it's not a tractor. 1985 2wd Ranger short bed w/ a 387 Windsor....stroked 351W Lightning motor, Windsor Sr heads, Eagle crank/rods, TRW pistons.
Nice, I love Rangers - I have a 2002 4WD with 4.0 V6 tweaked a little to about 280 HP, fun truck and it gets about 17-19MPG around town if I take it easy.
   / 1952 Ford 8N 302 v8 conversion #48
no thread- may eventually put it on the Grannys RX7 conversion site- but do enjoy seeing others- tractors ,trucks and cars
As to a conversion vehicle thread- i don't think one exists on TBN but not real sure, the rx7 isn't nice enough at this point and there are some things I would like to fix up on my tractors first :).
Dan that's a cool Ranger - probably surprised some muscle cars...:thumbsup:
   / 1952 Ford 8N 302 v8 conversion #49
I don't think you have to worry about axle hop on a tractor with no suspension.
xtn
   / 1952 Ford 8N 302 v8 conversion #50
xtn
They will hop even though they don't have a suspension.
Sent from my Samsung SPH-L710 using TractorByNet
2015 Hamm H7i VR-3 Single Drum Vibratory Soil Compactor (A49346)
2015 Hamm H7i VR-3...
Friesen 110 Seed Tender (A50515)
Friesen 110 Seed...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
2007 HYDRO-AX 764 MULCHING MACHINE (A51242)
2007 HYDRO-AX 764...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2019 Ford F-150...
