Firewood versus Pellets
/ Firewood versus Pellets #1
HillStreet
Maine
Kubota B2650HST. Kubota Z125S
I have burned firewood for 20 years and am thinking about switching to wood pellets. My house is single story with full basement, and the wood stove is in the basement. The basement ceiling is insulated (hot water radiant floor heating under floor between the floor joists), so I have a hood over the wood stove with an 8 inch round duct into the living room.
I burn 3 cords of wood a year and the 1400 square foot house is about 72 degrees during the coldest winter nights without burning propane in the boiler.
May go to pellets because: won't have to buy and stack wood; can buy pellets and stack them in the basement at my own convenience; no bugs with pellets; consistency of pellets compared with wood; wood is getting to be between $245 and $275 a cord and seasoned/ dry wood is getting scarce. Not to mention, wood delivery truck usually leaves ruts in yard, or I have to schedules delivery only during mid summer when I don't have enough time for it to season.
Has anybody made the change, and what has been your experience? I know I will need a new stove, and will have to retrofit my duct to get the heat upstairs. Thanks.
/ Firewood versus Pellets #2
My sister bought a pellet stove - actually an insert. She asked me what I thought of it after the fact/purchase.
Here were my concerns:
- there is only one manufacturer of pellets in our area... they dictate price and supply.
- if the power goes out how do you get the auger to supply pellets - - generator purchase.
- What happens if pellet stock is low and hard to find / this actually happened, people lined up(for hours 4-6) to get them and suppliers only offering so many bags to each person. Some suppliers were out of stock for weeks.
- a wood-stove in the basement would have heated the whole house not just a section. She has fans everywhere trying to direct the heat to all parts of the house.
With a regular wood stove it doesn't matter if the power goes out... you got heat and can cook, boil water etc. If you run out of wood you can burn pallets, limbs etc.
She went with the pellet stove for most of the reason you are considering. I would keep the wood stove if you can and add the pellet if you desire. Have you looked into cost of pellets vs. wood for the same amount of btu's?
A lot of people up here are converting to heat pumps. If you have an open concept house they work great. They say it cost $1 per day to run them for heat/winter and AC/summer.
Good luck... huge decision.
/ Firewood versus Pellets #3
Never have had a pellet stove, so I can't compare directly.
Along with Lloyd_E's concerns about power outages, I have heard that the pellet quality can vary a good bit. I don't think you would have trouble getting pellets, from what I see around here, but I'd hate to have 2 tons (pallets) of pellets that turn out to be not so good quality.
The electronic control boards and blowers are expensive to replace; can be very expensive.
The pellets have to be stored where they cannot draw moisture if bought by the pallet. If stored in a basement, it should be a dry basement.
If you have them delivered on pallets and want to get them near the basement entrance, like the firewood, you still have ruts maybe.
/ Firewood versus Pellets #4
I was the same way, I was going to go with a corn stove with a battery back up thermostat. But we went with a jotule lp stove (battery thermostat) and wood stove in basement as a back up.
/ Firewood versus Pellets #5
I grew up burning wood and when I bought this house I put a pellet insert in place of the open hearth fireplace they had. I think you have just a much manual work with pellets are you do with wood. Both hauling in wood/pellets and filling/cleaning the stove. Pellets are a little cleaner in that you are not shedding bark, sawdust, etc. all over when bringing in bags of pellets.
You still have to clean the stove, possibly more often than with wood. One of the downsides to pellet stoves is the relatively low BTU output. I think mine is 40 or 50k, you can get wood stoves that put out two or three times that. (A quick search shows Harmon now makes a pellet stove that puts out 68k.) You can't just 'throw another log on the fire' when you need more heat, if it is on 'high' that is all you are going to get. If my house gets cold it can take most of the day for the pellet stove to warm it back up, my propane central furnace can do it much much faster and no doubt so would a wood stove of much larger BTU capacity. I have to fill my stove twice a day. I pull the heat exchanger cleaning rods each time to get optimum output. Sometimes you can instantly feel the difference if the heat tubes built up a coating of ash.
Pellet stoves also warm the air, not the objects. No radiant heat with a pellet stove so you have to be able to push the warm air around. Power outages etc have already been addressed so I won't cover those same with expensive replacement parts. I will say I put in an outside air kit after having the stove a few years and that made a world of difference, no more negative pressure to draw in cold air. Cut my pellet usage and the house feels more comfortable, especially in remote rooms.
/ Firewood versus Pellets #6
It takes close to 1500 lbs of pellets for the same heat as a cord of typical hardwood. So you would need somewhat over 2 tons of pellets to match your wood usage. Just be aware of a couple of things. Without power, your pellet stove will not work. So a small generator is needed in case of outages. Also watch where you store the pellets. I few people in our area had a ton or two of pellets in the basement when they got some water in the basement. They ended up with a ton or two of wet sawdust. Completely unusable in the stove and a pain to get rid of.
paul
/ Firewood versus Pellets #7
My first winter I had to store my pellets outside on their pallets and I was really sweating one day waking up to a couple tons of wet sawdust. Since that time I have always broken the pallets down and re-stacked the bags on pallets in my garage (mainly because I fetch the pellets with a trailer but don't have a forklift to move the pallets into my garage without breaking them down). However I have since noticed many places that sell pellets around here store them outside and often through the winter/summer and sell them the next fall and they are fine. They are in a sealed bag (unless it has had a hole poked in it) and the whole pallet covered with a heavy plastic cover. Even with bags that have a hole punched in them and get wet the pellets near the hole turn to wet sawdust but the rest in the bag are usually fine.
/ Firewood versus Pellets #8
Yep, I see them stacked outside here too at the hardware, stove shops, etc. They will obviously take some weather as long as the bag is good, and/or covered. I don't know if different brands/makers have better or worse bags. Bag quality would be something to evaluate.
/ Firewood versus Pellets #9
I have a pellet stove in my basement and a wood stove on the main level. As mentioned above there is pros and cons to both. I like the pellet stove, fill it once a day, clean it once a week, it's been issue free for 10 years ( Harmon model). What I don't like about it is the fan, it's loud, or too loud for my liking. If I had to pick one, I'd probably pick wood, just can't beat wood heat.
Good Luck
Harvey
Wow, better information from all of you than I could have hoped. I will say that my setup for wood is pretty efficient--- I have a shed that holds 6 cord so I keep it stocked 2 years ahead. If I shop around I can probably get a better price on green wood. I tried log length years ago and that's not worth the trouble of handling it too many times. I was not considering the change to avoid work because it really doesn't take that much time.
I definitely like wood heat, and I spend a lot of time in the warm basement during the winter on fix-it projects that I save specifically for winter down time.
As for now, I might just stay with the sure thing that I know and not change to something that may not be as good. Thanks to all of you for your help.
/ Firewood versus Pellets #11
I don't have one, but have stayed in several camps which do; and can attest to their noise. Not just the blower, but the auger can be rather loud. If you have it in the basement noise may not be such an issue though.
/ Firewood versus Pellets #12
I have burned wood for several years, and now pellets for several years. most of the pros & cons have been covered. Wood takes more space to store, more work to move, dirtier, more cleaning of the stove. Pellets take less space to store, cleaner, easier to run the stove, but needs electric. I buy enough pellets in the fall to cover the entire winter, so I don't run short. (still need 1 more ton this year). I have 2 pellet stoves, an old manual one that was fairly inexpensive, and a newer mostly automatic Harmon XXV with self ignitor, large ash tray, temp controlled, where all I have to do is put in a bag a day, and clean out once a month. Very little chance of a chimney fire with pellet stove, I had a chimney fire once with the wood stove. I burned the wood stove 24/7, lot of work to keep wood in, clean out the ashes while running it, moving wood from the pile to the house, and harder to regulate the heat. The plus is it makes a lot of heat. I still have my wood stove, but never installed it when I built my new house. I keep thinking I'll install it in my barn some day. My old pellet stove heats my garage.
/ Firewood versus Pellets #13
Harman PC45 will burn wood pellets, any grains and unoffically stoker coal. One of these stoves will allow flexible fuel usage.
/ Firewood versus Pellets #14
I have both and my experience is the pellet stove is GREAT as a supplemental heat source. Compared to using my fireplace for supplemental heat it is much easier to deal with. I have an inverter to use when the power goes out and I have 3 fully charged deep cycles in the boat in the garage. I've never had to hook it up though.
As a primary heat source my experience would not let me add much info. We have natural gas that is usually pretty cheap. That's about as easy as it gets!
/ Firewood versus Pellets #15
Some years back, we bought a pellet stove. A big mistake for us. Of course, part of our mistake was the stove model and having an incompetent installation.
Our pellet stove is a major pain (literally) to clean. It does not do a good job of heating the house. The blower is noisy. I have sat five feet from it and been chilly.
They are best as room heaters, not whole house heaters.
Two years later, we bought a modern wood stove. VERY happy with it. It does a much better job of heating the house. Of course, since we have plenty of wooded land, the firewood is "free".
I would get rid of the pellet stove except for the 8" hole that we have in the stone exterior of the house.
Pellet quality has been very variable and mixed since we bought the pellet stove. "Back in the days", pellet raw material was a waste product and plentiful. Now it's in short supply and qualify varies no matter what brand you buy.
/ Firewood versus Pellets #16
That is a big con with mine as well. Being an insert space is limited and it just a tiny ash pan for cleaning out the firepot. The rest of the ash, the 'fly ash' collects in the firebox around the firepot. An ash vacuum to the tune of about $200 is pretty much required if you want to do it fairly quickly and cleanly.
One pro I forgot was the ability to use a thermostat on a pellet stove. This is certainly a nice feature over a woodstove which, if you overload it, the best you can do is close all the dampeners and hope it doesn't run you out of the house.
/ Firewood versus Pellets #17
Wow, better information from all of you than I could have hoped...
You might want to search TBN for pellet stoves since this is a somewhat frequent conversation. Some of those discussions are, well, quite heated, :laughing::laughing::laughing:, but informative. I THINK most of the pros and cons have been discussed but you might pick up some more information in the other threads.
Later,
Dan
/ Firewood versus Pellets #18
There are nice things about pellet stoves, but ... it's sort of removed from traditional rural wood heat conceptually.
The need for wood pellets adds a layer of supply and cost that you don't have much control over. In that sense, it's just another fuel like propane, electric, etc. Since I own plenty of wood for fuel (as long as I pay the taxes :laughing:) it seems counter-productive to invite in an uncontrollable unknown.
/ Firewood versus Pellets #19
IMO, the best resource is hearth.com. They have reviews of different stoves, wood vs. pellets, etc.
In my particular situation, the Harman Advantage is extremely difficult and messy to clean. I know one person who sold his because of this and bought a different Harman that's easier.
Harman's warranty is only as good as the particular dealer. The dealers have protected territory so you don't have a choice. If the dealer doesn't want to bother with warranty issues, you are totally out of luck. Harman will not do anything except refer you to the dealer, who will do nothing.
Other people may have excellent dealer support. We do not.
Also, our dealer installed the stove in conflict with Harman's directions (and probably in conflict with code.) I believe that is part of why we have poor performance.
/ Firewood versus Pellets #20
I order 2 or 3 pallets in late Spring for delivery in the summer and no problem with supply. Some use an over sized pallet machine to take them off the truck and place the pallets where you want them without any damage to the yard. The higher quality pellets make less mess and for easier cleaning. This year I went with vermont pellets after looking at this Maine based web site: woodpelletreviews.com. Looks like with these the hopper will need emptying about once a month, still need to clean out the burn pot once a week.
