Why No B2630 in Kubota's "Prior Products" Page?
/ Why No B2630 in Kubota's "Prior Products" Page? #1
My Hoe
NYS--Various Parts
Kubota B3000HSDCC, BH77, 5' Belly Mower, 6' Hyd. Angle Plow
Hi all,
I was trying to find the detailed specifications Kubota used to list on their site, for the recently-discontinued B2630. I went to "Prior Products" and they have B's goiing back to 1974, but no B2630, from the early 2000's, ending in, I believe, 2010. The page for "Prior Products" for the B's is Kubota Tractor Corporation - Prior Product - BSeries
And even then, they just list a few pieces of basic info, as you can see--horsepower, tranny type, etc....
Does anyone have a link to Kubota's old, comprehensive specs info for the B2630?
I'm also interested in the same info for the pre-2011 L series.
I did find a non-Kubota site with some info I recognized as being correct, but it doesn't list everything, like Kubota did. This site, for the B2630, is here:
TractorData.com Kubota B2630 tractor information
Does anyone have any experience with the above site, to know if its info is 100% accurate? One reason I ask this is they list the width of the B2630 as follows:
"Width: 53.7 inches [136 cm]" I don't believe they'd list it with an FEL bucket on it, and I do not remember the rear wheel track being nearly that wide. Am I "losing it?" :eek:
Thanks much, in advance.
/ Why No B2630 in Kubota's "Prior Products" Page? #2
Here's a cut and paste from a 2009 Kubota Wholegoods catalog. Not very well formatted, but it should give you the basic spec's.
Premier B-Series
B2630HSD
* * * EQUIPMENT IN STANDARD MACHINE * * *
DIESEL ENGINE
Model # D1105E2D21
E-TVCS 3 Cyl., 81.5 cu. in.
+ 26 Gross Eng. HP
+ 19.5 PTO HP
@ 2800 Eng. rpm
12 V - 36 Amp Hour Battery
Charging Output 14.5 Amps
Radial Air Flow Cooling
Dual Element Air Cleaner
Interim Tier IV Engine
HYDRAULICS
Open Center
Dual Pumps
Hyd. Pump Cap.
4.23 gpm Power Steering
5.6 gpm Remote Output
9.8 gpm Total
Cat l 3-point Hitch
at Lift Point lbs.
24" Behind 1676 lbs.
FRONT AXLE
Hydrostatic Power Steering
Cast Iron
Bevel Gear, 4WD
Tread Spacing - Nonadjustable
DRIVE TRAIN
Hydrostatic Transmission
Forward Speeds
Hi Range 0 - 11.5 mph
Med Range 0 - 5.3 mph
Lo Range 0 - 3.1 mph
Reverse Speeds
Hi Range 0 - 9.2 mph
Med Range 0 - 4.3 mph
Lo Range 0 -2.5 mph
Rear Differential Lock
Multi-Plate Wet Disc Brakes
FLUID CAPACITY
Fuel Tank 8.1 gal.
Cooling System 4.2 qts.
Crankcase 4.3 qts.
Transmission and Hydraulics 4.76 gal.
TIRES AND WHEELS
Front 180/85 D12 R1
Rear 12.4 - 16 R1
POWER TAKE OFF
Independent Rear and Mid PTO
Rear PTO 1 Speed
SAE Std 13/8 Six Spline
540 rpm @ 2768 Eng. rpm
Mid PTO - 1 Speed
2542 rpm @ 2800 Eng. rpm
SAFETY EQUIPMENT
2-Post ROPS w/Retractable
Seat Belt
Flip-Up PTO Shield
Safety Start Switches
Electric Key Shut Off
Parking Brake
SMV Sign
Turn Signals / Hazard Lights
PREMIER PLUS FEATURES
Tilt Steering Wheel
Deluxe Cruise Control
3 Pt. Lower extendible links
Ratchet right link
Enclosed operator controls
Chris,
Thank you very much! That has a lot of what I need.
Do you have a link to the "Kubota Wholegoods Catalogue?" (I've never even heard of such a thing).
Unfortunately, I really still need the B2630's wheelbase and turning circle, which I want to compare to the L's. Maybe someone else knows where this stuff is archived, digitally, and will respond?
And does anyone have ANY idea why the "Premier B's" would be in NEITHER the current model info, nor in Kubota's "Prior Products" listings? (The the "Prior Products" listings are next to useless, listing only a few datapoints per tractor, like Model Number, Horsepower, etc...).
I wasn't interested in the L's until lately. So I need the same, detail-intensive model info, for them, as well. I'm only interested in pre-2011 models, in B's or L's.
So if anyone has a link to the very-detailed specs Kubota USED to put up for these near-current, late model tractors, I would very much appreciate it.
Thanks again, Chris, and any others who can help.
My Hoe
/ Why No B2630 in Kubota's "Prior Products" Page? #4
My Hoe,
Here is a link to the Kubota Canada page for the 2630 spec's. Looks like the 2630 is still available in Canada. Happened to notice it this morning while I was checking out the new 3350 brochure. Hope it helps. If not, let me know, as I do have a brochure somewhere with the 2630 in it. I could scan it in if you need it.
Products: B2630HSD-F Kubota Canada Ltd.
Russ
My Hoe,
Russ
1savoy,
Hey--this is EXACTLY what I needed--thank you! So no need to scan your brochure, but thanks very much for the offer.
I do have a question: when you say " Looks like the 2630 is still available in Canada." is that based on the fact that they still list the B2630-F on their site, or do you have knowledge of specific units at a dealer(s)?
Either way, I'm in NYS. Can you make a recommendation of any dealers I might try, that you think are good to deal with? If not near NYS (Ontario is right across the border, if I drive 7 hours and do the bridge) I'd take recommendations of ANY dealers you've found to be good to deal with.
Feel free to PM me on the dealer info, if you like.
Do you (or anyone else?) know what the "F" in "B2630HSD-F" stands for? Freezing? (As it's an open-station machine in Canada?) :laughing:
Thanks again, savoy!!!
Peter
/ Why No B2630 in Kubota's "Prior Products" Page? #7
Chris,
My Hoe,
Just saw your response. If you PM me your e-mail address, I'll send you a PDF of the Wholegoods catalog for current products - doesn't have the B2630 (that I saw), but it does have just about every current tractor. Basically a list of all the tractors, implements and dealer installed options with MSRP. Somebody posted a link to it here a month or two ago, so I downloaded it and saved it to my laptop.
/ Why No B2630 in Kubota's "Prior Products" Page? #8
My Hoe,
That is funny about the "F", I like it. The 2630 being available in Canada was just assuming since they have it listed as current on the Canada website, it must be a current model. That could possibly be not true. Just a guess. As far as a recommendation for a NY dealer, I would highly recommend Alexander Equipment in Alexander, NY. I am not sure where you are located, but if near western NY, give them a call. You will probably talk with Tom Sr. or Tom Jr. If you talk to them, tell them Russ Cramer says hi. They are great guys and since I am now in Texas, I do not get to see them anymore. If you don't mind buying from a distance you can not go wrong checking with Brady Barlow at Barlow Equipment. Emailing Brady is probably the best way to communicate with them. Hope that helps.
Alexander Equipment | New and used equipment for personal, agricultural and industrial use in Alexander, New York.
Home | Barlow Equipment
bradybarlow@gmail.com
Take care,
Russ
My Hoe,
Chris,
Thank you, very much. Even though I'm interested in the last generation's tractors, it is helpful to have a resource to compare them to, i.e., the current generation. And I don't care for the way Kubota just dropped the B2630 and B3030 into "limbo-land," i.e., they're not in "Prior Products" (which goes back to the 1974) yet they're not in the current catalogue, either.
I realize the B2630 may not be in your link, but if possible, I may print stuff from your link, to hold in my own, personal archive, because Kubota seems somewhat random in their record-keeping, as described above.
Sending PM now--thanks again!
Peter
My Hoe,
Take care,
Russ
Russ,
At first, I didn't know what you meant about the "F" being "funny." But then I reread my post (and I'll repeat my own joke, here, because I'm shameless:
"Do you (or anyone else?) know what the "F" in "B2630HSD-F" stands for? Freezing? (As it's an open-station machine in Canada?)" And I got it--thanks!
And thank you for the tip on good NYS dealer. I used to live out in Western NY--God's country. Loved it. Great people, great music, people snowmobiling to school--on the roads, in traffic. :)
But what I was actually asking about was recommendations for any Ontario/Quebec-area Kubota dealers--or, if no eastern Canada ones, then ANY Canadian dealer you like and found trustworthy. I'd like have a conversation about the "F," and learn if there's any inventory left. Also, I'm concerned about whether or not I'd have to pay an import duty (or other "hidden" charge) if I bought from a Canadian dealer.
And thank you for the links. I've been in contact a few times, with Barlows, but on a couple of different models, and each time, none in stock. But you're right, if I was going to buy "sight unseen," I'd be most confident with Barlows, given all the good press they garner here from regulars like John Thomas, etc....
But it's good to know of a NYS dealer you have confidence in. I will call them, too, as before this, there was NO NYS dealer I was impressed with--or even that I thought was likely to tell me the truth.
I will definitely tell them you said "Hi!".
Thanks again.
Peter
2017 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A62129)
2017 CATERPILLAR...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
Pallet of Two Pivot Wheels & Tires (A62177)
Pallet of Two...
2006 KOMATSU PC300LC-7 EXCAVATOR (A62129)
2006 KOMATSU...
2012 Ford F-350 Service Truck (A61568)
2012 Ford F-350...
UNUSED CFG INDUSTRIAL QK20R MINI EXCAVATOR (A62130)
UNUSED CFG...
