Buying Advice Round Baler
/ Round Baler #1
sai1997
WI
johndeere 5303
I have a John Deere 5303 56hp pto.I looking to buy a round baler, just wondering what baler will work?
/ Round Baler #2
Your tractors hp will limit you to a smaller baler such as a 4X4 or 4X5. Some baler models have the option of making both size bales. JD 456 or 457 might be a good choice or Vermeer 5400
/ Round Baler
Thank for the info.
/ Round Baler #4
your tractor will max out at 4 by 5 baler.
/ Round Baler #5
Have a Vermeer 5400 Rebel. Pulled with 60 pto hp. Nice baler but would move to a 5410 or 5420 so I could get net rap. Makes a big difference on storage. John Deere makes a good baler but when I was comparing them the deere's were a lot lighter than the vermeer rebel.
If you get a chance go to the Vermeer website and read plus watch the video on baler history as they invented the round baler.
Good luck.
/ Round Baler #7
At one time Vermeer advertised only needing 40 HP for a 4X5 baler
Vermeer rebel 5400, 5410, or 5420 are all 40 hp minimums. Plus the out weight the comparable Deere version by about 1,000 pounds. I think Deere says theirs needs 50-60 hp but not real sure on that.
/ Round Baler #8
Good luck.
I can recall the first round baler I saw in our part of the world. It was a Hawk-bilt, and it rolled the bale on the ground instead of cradling it in the belts that Vermeer used. But before that, there was a round bale system used by Allis-Chalmers and didn't use string wrap. It made a small round bale that weighed about 50 lb. A neighbor had one back in the '50's and stored his hay outside thru the winter.
Butch
/ Round Baler #9
I run a JD 375 that makes a 4' diameter by 5' long roll and is operated with 57 PTO hp. Nice combination and plenty of power. Guessing the roll weights around 750 give or take 100. When I bought it I was looking for a smaller baler than the 6' diameter by 5' long balers I had been running (JD 500 series). No 4x4s 5s or 6s were available. I find this bale is easily handled and only being 4' in diameter it's easy to see around on the FEL. However, I'm not sure that the larger diameter/shorter length of the 4xs isn't better for long term hay storage outdoors. Net wrap is popular and I feel that it does a better job of protecting hay for long term storage but twine wrap works for me and that is what I stayed with. It is more easily controlled (by me) in the feeding process.
Mark
(APPROX. 18) 27' 26G - 5V GALVALUME TIN PANELS (A63290)
(APPROX. 18) 27'...
Electric Tricycle (A64194)
Electric Tricycle...
SDlanch SDLGC80 (A60462)
SDlanch SDLGC80...
AGROTK SPA84 84" Dozer Blade (A62183)
AGROTK SPA84 84"...
Rhino 4155 15' PT Batwing Mower (A62180)
Rhino 4155 15' PT...
2020 WIRTGEN WR200 XLI SOIL STABILIZER (A62129)
2020 WIRTGEN WR200...
