L5740 (interim tier 4) or L6060 (tier 4)
/ L5740 (interim tier 4) or L6060 (tier 4) #21
I don't care for diesel exhaust and my wife absolutely HATES the smell, we didn't experience a problem with our L5030HSTC or L5740HSTC.
Good to know the earlier tractors have no smell as well, I don't have enough time with them to have said. The l40 I ran for a while did the usual black puff now and again and certainly was not bad.
/ L5740 (interim tier 4) or L6060 (tier 4) #22
Oh, I imagine they have a smell, it just doesn't make it into the cab. Our L5740 Tier IV puts out a lot more smoke on start-up than our L5030 did. On our M8540, it will put out a bit of black smoke on sudden engine load, so no doubt the exhaust is cleaner on the L60/M60. The Tier IV was only one of several reasons I bought before the L60 came out. What is important to me will be a negative for others I am sure; no intention to run the L60 down as it's a really good machine.
/ L5740 (interim tier 4) or L6060 (tier 4) #23
The L40 has less on it than the L60. IE emissions. I sure miss my 12valve cummins. If something broke, they were so easy to fix. And parts were much cheaper. If I had the option, I would pick the 5740. Mine does smoke at cold start, but then cleans right up even under heavy load.
/ L5740 (interim tier 4) or L6060 (tier 4) #24
if you can still get a 5740 then go for it. Known animal.
Around here no l40's left when I needed a tractor except a couple small ones.
I ended up getting a new (still in crate) L5740 with R4s, FEL, 2nd front hydraulic for future grapple and +/- snow blade. Paid $1K or so more than I thought market should be, but there aren't many left. I liked the smaller cab of the 5740 and the only thing I liked better on the 6060 was the loader control. The JD 4720 was probably too tall for my barn, as it has "regular' garage doors. I liked it OK, but I guess I'm just used to Kubotas. The JD pricing was very aggressive, but I liked the Kubota better overall. I have woods and the extra height of the JD would have been a minus.
Thanks for the info! Keeping my L4300 for now...
/ L5740 (interim tier 4) or L6060 (tier 4) #26
congrats, I am jealous. I think you were smart to do with the known.
thanks. I'm looking forward to the AC in the summer!
/ L5740 (interim tier 4) or L6060 (tier 4) #28
Congratulations on your new tractor, you sure are lucky to have found one. I will be interested in your impressions when you get some seat time.
Thanks. The dealer had the last 3 for miles around, hence the higher price. I plow with my Ranger (so far), so it probably won't get much use until spring.
2005 Honda Accord LX Sedan (A59231)
2005 Honda Accord...
SKIDDED WASTE WATER FIBERGLASS TANKS (A60736)
SKIDDED WASTE...
Used Landpride GR1525 Stump Grinder
Used Landpride...
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
2006 Ford F-350 Pickup Truck, VIN # 1FTWX31P16EB57079 (A61165)
2006 Ford F-350...
1991 TRAILMASTER CRUDE TRAILER (A60736)
1991 TRAILMASTER...
