hydraulic pump (again)
/ hydraulic pump (again) #1
TonyD0558
Princeton,NJ
New Holland 555C, power trac pt 2425
New subscriber with a pt2425 that continues to go through hydraulic pumps (main). Has anyone ever found satisfactory fix and decent run time with one of these machines?
/ hydraulic pump (again) #2
How many hours are you getting before losing a pump? Which pump do you mean by "main", PTO or tram? Is your primary use hydraulic PTO or non-rotating implement?
This doesn't sound normal, and I don't recall anyone else having to replace their pump more than once.
/ hydraulic pump (again) #3
Welcome to TBN. Sorry for your pump issues. Perhaps a little more information would help.
Which pump is it?
The tram pump, the main PTO pump or the aux PTO/steering/FEL pump?
How many times has it failed?
Any clues from the factory?
It is the main pump that would supply power to the wheels. part# p154x19. This will be number 4. This time the pedals fwd and rev had zero tension or effect. then when re statrted the machine lept forward and continued forward untill shut down. Pt says send it back and pay $1000.00 to rebuild or $2000.00 to replace.
Killin my business...
It is the main pto pump. steering is fine.PT says ship it back $1000.00 to fix and $2000.00 to replace. part number is p154x19... 4th pump in under 500 total hours.
/ hydraulic pump (again) #6
The main PTO pump is not the same pump that supplies power to the wheels. ;)
The main PTO pump supplies power to the implements like mowers, brush cutter decks, trenchers, etc...
The aux PTO pump supplies power to the aux PTO (the knee lever operates the aux PTO) and also supplies power to the steering/lift circuit.
The variable volume pump supplies power to the wheels. Some folks refer to it as the tram pump or the drive pump. I think that is the one you are having problems with.
I have not heard of anyone going through multiple tram pumps. 4 is way too many.
What model year is the PT425 and how many hours are you getting on the pumps before they go bad?
Hi and thanks, yes the tram pump. I don't replace them myself a local shop does I just make the phone calls to P-T.
It was new model in 2005. I have only owned the business and the PT for the last five years and have used the machine for about 100 hours. Second time this has failed in those 100 or so hours.
/ hydraulic pump (again) #8
Stuck spool in the foot pedal cylinder?
4 pumps in 500 hours? Two the the last 100 hours? I can understand your being upset. I would confidently say that no one else on this site has that level of failure rate. I was expecting you to say something like "second pump in 2500 hours" (which would still be excessive).
When the last pump was replaced, did you drain and refill the hydraulic tank and replace the filter? Your oil must be contaminated to have that kind of problem.
I will make certain to replace the filter this time. as well as drain the hydraulic tank. Oil was contaminated last time but was clean this time. Frustrating, that when I use it on a job I wind up spending more to fix the machine than I charged for the job...
/ hydraulic pump (again) #11
on my 2007 model 425 the pistons in the fwd/rev. control would not fully seat and produce a whining sound (cavitation?) this started at roughly 300 hours, until it stuck in fwd (up a tree with the pt thread) until this happened I was unable to pinpoint the problem, repaired once, problem starting to resurface again after ten hours, personally I feel the pistons in the pedal control should have spring-loaded resistance or mechanical linkage of some type or form to prevent this problem, I would speculate if the seals are compatible with the oil in the system, our shop built 200 valve bodies with incorrect type of seals once
/ hydraulic pump (again) #12
I know I don't know as much as much as many on here, but one question that struck me was, are you bleeding the system after changing the filter? I wasn't sure if you bought it used or not, but if you did you may not have gotten the manual and might not be aware. Just want to eliminate all the simple things
2017 Ford Explorer AWD SUV (A64557)
2017 Ford Explorer...
2022 CATERPILLAR 313GC EXCAVATOR (A65053)
2022 CATERPILLAR...
2020 Chevrolet Tahoe SUV (A64194)
2020 Chevrolet...
UNUSED JCT 60" PALLET FORKS (A65055)
UNUSED JCT 60"...
1989 CUTOM 15T-100 EQUIPMENT TRAILER (A66091)
1989 CUTOM 15T-100...
2017 Nissan Altima Sedan (A64557)
2017 Nissan Altima...
