LED Work Lights
/ LED Work Lights #1
TexasBoy
Gold Member
Central Texas
Kubota M7060HDC12, L4600DT, Ford 4000
A while back I was doing lots of reading here on TBN and had read a thread on this site where a fella mounted some LED lights on the fenders of his Kubota as work lights. As I recall he mentioned something about there being wiring already pulled for that and he put these lights in some pre-drilled holes? This was a while back and I went back to read it again and just cant seem to find it. I tried the SEARCH function and still no luck.
Any of you guys have a bookmark to that thread? Id sure like to see his setup again.
/ LED Work Lights #2
Under the left fender on my L3200 there is a plug 2 female spade connectors in a T configuration. They are ignition switched.
I'm just unplugging one spade connection for my ROPS lights until I have time to wire in a proper switch.
/ LED Work Lights #3
On my Grand L there are three connectors by the right rear corner of the seat. They are connected to a 10 amp fuse and are for the work light. I don't know of any predrilled holes on the fenders.
/ LED Work Lights #4
Looking at ways to wire Jo my work lights....found that connector you had mentioned... Noticed its power on always with key in on position...
How did you end up wiring it. I have the L3800 so it should be the same as your 3200
Thanks
/ LED Work Lights #5
I have a l3240 and mounted toggle switches for my LED lights in the side if the plastic cover for the lift/ pro controls. They are just below the arm rest, somewhat protected but easily accessed.
/ LED Work Lights #6
/ LED Work Lights #7
Thanks
I tapped into the wire in or near the fuse box up front. Put a switch on the dash.
Until I got that done I just had spade connectors crimped on & unplugged em out of the connector under the fender to turn em off.
/ LED Work Lights #9
Thanks guys. Lots of good info. Will post when I get it all wired up... Hopefully tomorrow
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
New/Unused Electric Winch (A65583)
New/Unused...
2019 Merlo TF 42.7 (A60462)
2019 Merlo TF 42.7...
4ft Mini Skid Quick Attach Rotary Cutter (A63689)
4ft Mini Skid...
