L4060 on its way!
/ L4060 on its way! #1
adventure bob
Here
JD 345/ Kubota Side by/ kubota ??
Posted in the newb forum 2 weeks ago that I was possibly buying now I have the SN and all the paperwork! I'm gidy as an 8 yr old on Christmas! Its getting the third function put in as well as a blk heater and chain hooks welded onto the bucket.
We have 8 acres that were burned last summer so I have a butt load of trees to move and cut as well as grassland recovery. The fire was so hot on our property that it sterilized the dirt. Weeds aren't even coming back; its just scorched. Next purchase is the wicked grapple.
/ L4060 on its way! #2
Congratulations. Those are nice tractors and you know you got a good reliable machine with Kubota. Did you get quick attach on front of the FEL? Pictures when you have them please.
/ L4060 on its way! #3
Congratulations. If you have many large Stumps, please remember that your tractor isn't Heavy Machinery like an Excavator or Dozer.
/ L4060 on its way! #4
Congratulations on your new tractor.:thumbsup:
/ L4060 on its way! #7
Congrats on the purchase.
Definitely get a Grapple of some type. It'll increase your productivity a hundred times over. Also will make you a very lazy man. My Grapple is on my tractor 95% of the time. I do a lot of timber work. Rarely pick up a tree limb by hand.
Also, with a Grapple you are gonna need some ballast. Load the rear tires with fluid, non corrosive, I used windshield washer fluid. Might want some 3pt ballast as well. I carry around my 1200lb box blade most times, unless in congested timber, then it gets in the way.
/ L4060 on its way! #10
That's a nice sized machine. And with the l4060 your get a bit more clearance between the fel connections and the front wheel than the next size smaller which I think is a big deal.
/ L4060 on its way!
My delivery was pushed to Monday, man its worse than waiting with your sled for the first snow.
/ L4060 on its way! #13
As soon as it shows up you won't even remember it was delayed. Congratulations on the investment.
/ L4060 on its way!
I have it, I put 5 hours on it, Got it all dirty and scrtched the bucket up. Anyone have link ot lights for the back other than the Kub light kit? I want something really bright, thinking LED but want to get a stock looking switch.
/ L4060 on its way! #15
Have you checked out the threads by 4shorts?
/ L4060 on its way! #16
Pictures please. Or it does not exist. We like new tractor pictures.
/ L4060 on its way! #17
I recently put rear lights on my L4240 HSTC,yours"may"be similar.Purchase the stock switch from Kubota(fits the pre-wire and hole),tractor should be wired for the rears,mine was taped to the flashers .
/ L4060 on its way! #18
Congrats on the tractor. They factory lights are more than bright enough for a tractor. If you want something really really really bright checkout Baja Designs Lights.
/ L4060 on its way! #19
I don't think the Kubota rear light kit was too expensive but all you really need is the switch because the harness is already there. The brackets they supply come off the hazard brackets. The rear lights kind of suck and I have been thinking of brighter ones. I think I have the same ones on my m135GX and they won't even light up my implements to work much past sundown.
/ L4060 on its way!
I cant find an interior switch so the reflection off the back window makes it impossible to see when backing up. Anyone know of an interior dimmer?
