nylon tow strap
/ nylon tow strap #21
Oil rig anchor chain breaking:
oil rig anchor chain snaps near death - YouTube
I broke a chain trying to drag a large stump a dozer had left, totally uprooted. The chain recoiled about 20 feet and hit my tow vehicle quite hard.
Anything that stretches will recoil when suddenly released. The more stretch, the more recoil. I believe that chains that just fall were not stretched, but just had a weak link.
Bruce
/ nylon tow strap #22
Where did you get the strap? What was it made for? It sounds pretty strong but as others have said you can ruin it pretty easily if you wrap it around logs and skid them with it. If you do use it I would put a chain around the log and fasten the end of the strap to the chain. I have a set of chains with regular chain hooks on one end a big J hooks, like wreckers use, on the other end. They are nice to use with a strap. The big J hook is easy to hook to your strap and it will not damage the strap.
/ nylon tow strap #23
I'll take a pic of my tailgate from my last snapped strap experience. It's not the worst that i have ever seen but its still significant. I am speaking from personal experience with both straps and chains when being used to retrieve very stuck vehicles.
/ nylon tow strap
The question was asked where I got this from. I got it at our City auction. It was used by the street department or the utilities/water department. On the box for the sale it said tow strap./rope. It is quite heavy, I first thought it might have been used by the fire department as I felt it looked heavy enough to pull out their trucks but they said it did not come from their department.
I am quite sure my 4 wheel tractor would not have enough power to break the same. The ideas listed will help, I have 7/16 inch chain and some 1/2 inch and I have some 1/2 inch steel cable but it is pretty heavy and relatively stiff to work with. Thanks
/ nylon tow strap #27
Hi Bruce,
That was the scariest episode of chain breaking I have seen. That big a** chain was certainly air borne, and headed for that rigger's head. He must have a guardian angel.
Thanks,
Thomas
Bruce
/ nylon tow strap #28
The concern about abrasion is very real. I was lifting a log with a fairly think strap once and was using the roll of the bucket to get a little more lift. I knew the edge of the bucket would contact the strap but I thought it would be okay if I did it slowly. Wrong. It sliced like I was cutting it with a shears. That strap has a knot tied in it to remind me how fragile they are if abraded and I use it for light lifting only now. For clean unabraded pulling they are fine.
/ nylon tow strap #29
Bumper to bumper and take a run with straps. Sometimes use two to extend the length. They stretch nicely and ease the jerk! Course they do break with related damage to surrounding items! Seen a flew incidents like this. Of course I didn't do that or should say "Have a strap break".:D
Oilfield work with lots of company p/u's having to drive in mud and snow.
/ nylon tow strap #30
Well that's a lot "heftier" strap than I envisioned in my first reply. I think you'll be ok (x4)! Just protect it from dragging in the dirt, and on the tractor end, from any possible cutting action.:thumbsup:
/ nylon tow strap
I did not describe it very well in the first posting so I understand, my fault on that.
/ nylon tow strap
I got a twisted clevis that should work for a chain attachment.
/ nylon tow strap #33
Very well put, took the words right off my keyboard. I pulled a hopelesly stuck semi-truck once fully loaded (about 45 tons) with a D6 using a 6" nylon tow strap. I pulled hard enough to break the strap and all it did was create a lot of dust as it fell down to the ground. Had that been a chain: the truck probably wouldn't have a radiator or engine block left and I wouldn't be typing right now. At this particular job, if we (employees) were caught using a chain; fired on the spot! On another note: me and dad were pulling tree stumps out with a 3/8" chain, dad was taking runs at it jerking it, and faster than a blink of an eye, the chain broke, shot right past my face, punctured the rear tire and flattened it, instantly! I do not own any chains on my property or businesses, only straps. They're inexpensive and last a reasonably long time.
IRANCH IRGC40 ELECTRIC SCOOTER (A64280)
IRANCH IRGC40...
2005 Amadas 2100 (A64126)
2005 Amadas 2100...
John Deere Starfire 6000 (A64126)
John Deere...
Landhonor SAD-12-23C Skid Steer Mount Auger (A62679)
Landhonor...
2013 BMW 7 series Passenger Car, VIN # WBAYE8C53DD133972 (A65563)
2013 BMW 7 series...
NEW ATA-EPC40 Plasma Cutter (A62679)
NEW ATA-EPC40...
