Your towing rigs and trailers
   / Your towing rigs and trailers #1,543
Good luck with it...I love the duramax ,and it is strong but not as reliable as the 6.0, they are ultra reliable and last a long time with minimal repairs....I have an 04 duramax and it's great but it needed a 5k set of injectors at 120k,my01 gmc 8.1 big block loves gas but zero problems and lots of pulling power.
   / Your towing rigs and trailers #1,544
2009 2500HD Duramax/Allison 4x4 crew cab towing a 31ft Regal cabin cruiser on tri-axle galvanized trailer. The boat dry weighs in at a little over 5 tons, about 11+K lbs with gas, water, etc. The 2500HD with Dmax/Allison is rated at 13K, however, in 2009 the 2500HD hitch was the standard GM hitch put in everything including SUVs. IIRC it was rated for 7.5K or 12K w/WD, pretty woeful for a 3/4 ton pickup. Plus there were more than a few reports of problems/failures with the OE setup. No way I was going to pull this load with this hitch, so I ended up with a Draw-tite class 4 15K hitch.
Here's my other towing rig, Kubota B26. Pretty tight quarters maneuvering the boat around the corner of the house, so I'd back up the boat to the corner with the 2500HD, unhitch, then take it the rest of the way with the B26 using a hitch receiver welded to the quick attach pallet fork attachment.
   / Your towing rigs and trailers #1,545
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=344344"/>
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=344345"/>
What's the beam on that baby? 31' long I'd think would be over 8.5' which is all I can tow.
   / Your towing rigs and trailers #1,546
Nice boat.
Chris
   / Your towing rigs and trailers #1,549
Beam is 8 1/2', exactly the max width allowed under California general rule. I was stopped once by CHP, allegedly to verify width, but he just wanted to check the boat out. He spent about 30min looking it over, asking questions about handling, offshore behavior, et al.
   / Your towing rigs and trailers #1,550
All loaded up for a couple days of fun.
1998 FORD F SERIES DUMP TRUCK (A57192)
1998 FORD F SERIES...
2022 CATERPILLAR 730 OFF ROAD DUMP TRUCK (A52707)
2022 CATERPILLAR...
Krone Easy Cut TC500 CU (A53317)
Krone Easy Cut...
2013 Chevrolet Equinox LTZ AWD SUV (A56859)
2013 Chevrolet...
MCELROY COOL PACK 20 (A55745)
MCELROY COOL PACK...
Ford F450 Bucket Truck with Altec AT200A Boom (A57024)
Ford F450 Bucket...
