FEL mounted hydraulic tree spade
/ FEL mounted hydraulic tree spade #1
jgibbens
Hopedale, IL
Kubota BX 25D
I have a bunch of 1" diameter mullberry trees that I want to transplant for a firewood plot. Mullberry is a taproot tree so I need to get a root ball that's deeper that it is wide.
Is there any engineering related reason you don't see hydraulic tree spades with only two spades? I undertand that the top of the root ball would be more of a football wedge shape than round cone if the scoops are cut from large diameter pipe.
I don't have a drawing worked up yet but it would be an H shaped frame similar to a tree toad frame (heavier and with more gussets) and chained to a front end loader bucket the same way a quick spade is mounted.
Since the FEL bucket shouldn't need to change pitch, I'd replace those two cylinders with fixed links and use them to power the spades.
see anything wrong with the concept?
Finally making some progress. Here's the spades.
/ FEL mounted hydraulic tree spade #3
DO you have ASH trees in your area? The reason I am asking is Ohio is going to be so full of dead ash trees that one would not need to plant additional trees for firewood. Ash borer in 88 counties. Only reason I cold think of would be the additional curviture requiring more force going into the ground? Call Vermeer and ask one of their engineers.
I'm in central IL. Firewood around here is expensive enough that I'd rather grow my own. That and the mullberry trees are growing up in pine stands all around the house so might as well get some use out of them :)
Haven't had a lot of time to work on it but the frame is almost done. Here's a picture with the spades laying on the guides.
/ FEL mounted hydraulic tree spade #6
what ever happened to your project?
I'm deployed, so no progress lately. It works but needs larger cylinders. It also needs an anchor to hold the frame down while pushing the spades in. There are two upright pipes in the picture that capture a hydraulic motor. The motor drives and retracts an earth screw anchor to hold the frame down. It worked but needs improvement. I am going to replace the shaft of the earth anchor with an acme threaded rod to positively control the raising and lowering of the anchor.
/ FEL mounted hydraulic tree spade #9
Add weight to the bucket to help hold it down?
Looks great. Simple and ingenius.
I think that would work for a larger tractor. This one already has stability issues on my hill side.
2019 FORD F-150 STX CREW CAB TRUCK (A59823)
2019 FORD F-150...
2007 WELLS CARGO 16 ENCLOSED T/A TRAILER (A65643)
2007 WELLS CARGO...
Stout Brush Grapple XHD84-6 (A66285)
Stout Brush...
66in. Skid Steer Bucket (A65640)
66in. Skid Steer...
2022 CATERPILLAR 299D3 XE SKID STEER (A65053)
2022 CATERPILLAR...
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A64194)
2023 Caterpillar...
