Lift arm control
/ Lift arm control #1
avillahdw
Avilla, AR
2013 LS U5030
Hello Everyone,
Just wondering if anyone out there has come up with a way to raise/lower the lift arms from the rear of the tractor. I believe some models of Mahindra offer this and I can certainly see where this would be handy when hooking up implements if not using a quick hitch.
/ Lift arm control #2
I would like to know. My fenders have punch out that look like a place for switches.
/ Lift arm control #3
I don't need to access my controls, but I have in the past used a cane and another member simply uses a notched piece of PVC pipe.
/ Lift arm control #4
It's hard with the cab in the way.
/ Lift arm control #5
Guess it depends on the tractor, I just opened the back glass. I no longer use any open station tractors.
/ Lift arm control #6
I also open the back window.. and use a 1 1/4 piece of pvc about 4 ft. long with a groove cut one inch from the end.. I slip it over the lever and push or pull to lift or raise.. I have 5740C Montana and 990 John Deere,, Lou
/ Lift arm control #7
You guys are better climbers or taller I could see me falling back on the hitch. It's not to bad I work left to right then I am near the door when I can work it pretty easy.
/ Lift arm control
On my U5030 (non-cab), the lift arm control is down beside the right side if the seat, which is no problem as long as your in the seat. The ease if having a rear accessible control would be nice. I have a plan floating around in my head and if it works, I'll post pics and details. As this is a new tractor, I do not have my hydraulic top link or quick connect on yet.
/ Lift arm control #9
You mean like the one on the back of my Kioti?:). It doesnt look like it would be that hard to build some mechanical linkage to do this.
/ Lift arm control #10
I know rub it in.
/ Lift arm control #11
2018 Kenworth T680 (A64127)
2018 Kenworth T680...
2021 Kubota MX6000 (A62177)
2021 Kubota MX6000...
NEW ATS Mini Ride on Skid Steer (A62679)
NEW ATS Mini Ride...
2000 Sterling L9511 Triaxle Dump Truck, VIN # 2FZNNWYB8YAB42893 (A65563)
2000 Sterling...
SDLanch SDLGC80 (A64127)
SDLanch SDLGC80...
2002 FREIGHTLINER COLUMBIA DAY CAB (A62613)
2002 FREIGHTLINER...
