My MX5100 HST doing work.
/ My MX5100 HST doing work. #1
Wayne64SS
Duanesburg, NY
'13 MX5100HST, '82 B7100HST
I had heard it both ways before i purchased. It won't lift that. or It'll lift that no sweat. The "that" in question is 2000lbs of heating pellets. I have 5 tons delivered every year and was tired of manually humping them into my garage with the pallet jack or even worse having to unload by hand because the entry to my garage is very unlevel and sometimes the pallet jack hangs up. I'm very happy to report the MX5100 made short work of the ton we had delivered last night for our first fire. The rear tires aren't loaded but I did have the backhoe attached. No drama, no strain, nothing. I had heard from so many people it wouldn't do it I was really afraid it wouldn't. You know what they say.....
It was freezing out last night so I didn't really play around with height or anything, more of a get them inside and get the fire going kinda deal. When the other 4 tons come I'll see if I can't load and unload one from my truck bed etc.
:thumbsup::thumbsup::thumbsup::thumbsup:
/ My MX5100 HST doing work. #2
Nice, and with Ag/R1 tires too it looks like. How high was the pallet when you lifted it off the truck or trailer?
They were already on the ground when I got there. Like I said next time I'm going to see about getting them on and off my truck, I didn't want to mess with these it was too cold and they also weren't wrapped to the pallet at all so it would've been sketchy.
/ My MX5100 HST doing work. #4
You would be hard pressed to find anyone disappointed with a MX, its a nice affordable and reliable unit
/ My MX5100 HST doing work. #5
We get about 2 tons of pellets per year. We put them toward the front of our garage, so they are packed by hand, by me. My JD 2720 won't lift a ton, but my neighbor's JD4xxxx does just fine, but it won't fit in the garage. Oh well, sitting at a computer all day for work, lifting 4k lbs 40 lbs at a time is good, much needed, exercise! :)
What kind of pellet stove do you have?
/ My MX5100 HST doing work. #6
Nice! I love it when a good tool does its job!
How was the curl power on it? I usually run out of curling power before I do lifting power.
I have no idea how much this beast weighed, but it put my JD 553 loader to the test. And I'm glad I had my 600lb BB on the back with the rears loaded, because I was teetering all the way to the woods with this thing. Then again, I could not pull it up close to the pivot, so most of the mass was a couple feet out - making it tougher on the FEL.
Its a Harman PB105 Pellet boiler.
That's a whole lotta stump brother. The curl was awesome. It curled it no problem, however I couldn't curl it real far because of the bags being loose on the pallet. As I read the specs the curl is supposed to be the strongest part of the loader I thought?!?!
/ My MX5100 HST doing work. #8
That's what my manual says, too. But I ran out of rollback before I ran out of lift. Weird. Like I said, presumably because the mass of the stump was a good ways out from the pivot.
Anyway... I love the MX5100. That thing really is a little beast! Happy for you to have a strong little ox like that to get some timesaving into your usual jobs! :thumbsup:
Huh, that's really interesting. It should be just as bad lifting that far out. regardless that's awesome it handled it no problem looks like a helluva machine! I got really lucky if I had gotten something even an inch taller it wouldn't have fit in my garage. As it is i have to have the rops down to pull it in and out and it still hits on the door but just barely.
/ My MX5100 HST doing work. #10
I can see that from the pic, ha! Tight fit!
It's the same thing with me for my UTV. Glad I bought a JD Gator over a Polaris Ranger as the Gator is not as wide. I've already been in a few situations where the Ranger would not have made it through something the Gator did.
/ My MX5100 HST doing work. #11
see your finding out what the mx5100 can do.an it does mostly what its asked todo.i hated trading my mx5100 hst 4x4 with quicktatch la844 fel.but it couldnt do what we was asking of it.an i knew in the future we was going to need a cutter an rake tractor.
what were you trying to do with yours? I'm excited to be able to get the v6 Detroit out of my garage that's been taking up space for 2 years because i have no way to get it outside. LOL It's the little things in life sometimes.
/ My MX5100 HST doing work. #13
nice pics wayne,the mx will lift those no sweat-enjoy the new power !!!
From CT
/ My MX5100 HST doing work. #14
I'm looking into a MX5100 as well with the BH92 Backhoe. My garage door height is roughly 7 ft 3" and I have about 19 ft depth. If I back the tractor and extend hoe to clear door then turn it to the side I think I can fit it. How deep is your garage? And do you know you rigs length with the hoe folded to the side? Any info would be great. Thanks
/ My MX5100 HST doing work. #16
I have an MX5100--no loader-- and had no idea it would lift that much. A TON is a lot for a fairly small tractor. What a workhorse these tractors are.
/ My MX5100 HST doing work. #17
You are dang right the MX5100 is a heck-of-a-machine. Those are very nice tractors at a great price. People don't always need a beast of a tractor for some of the very reasons you mentioned ... It fits in your garage.
/ My MX5100 HST doing work. #18
I have a MX5100 with 300 hours on it now. The only complaints I have are the rear is a bit light, even with the loaded tires, I also don't like how high the rpm's have to be to acheive 540 on the pto ( although I mow at a much lower RPM just fine) also the diff lock should be on the left side not right so you can use the throttle while using the diff lock. Although i think they did move it to the otherside in the newer models.These are all really minor complaints though. I would buy another one in a minute.
/ My MX5100 HST doing work. #19
we was pulling a 4 bale hay hauler with it loaded with 4 1800lb 5 by 6 bales an 1 on fel.an it was more than the tractor could really pull.an even just pulling the hay hauler loaded it was all it wanted.so i traded it in on a 2013 7040SU rops 4x4 1153 loader.
ill measure it for you tonight if I remember.
2023 New Holland C327 High Flow Compact Track Loader Skid Steer (A64553)
2023 New Holland...
2016 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A64194)
2016 Chevrolet...
2013 HYUNDAI HL770-9A WHEEL LOADER (A65053)
2013 HYUNDAI...
Kubota L3901HST
Kubota L3901HST
Star (A64557)
Star (A64557)
2017 Ford Explorer AWD SUV (A64557)
2017 Ford Explorer...
