adapt a plow to a QA
/ adapt a plow to a QA #1
enterprisebbc
Ct
2008 CK35 Kioti
How do you go about adapting a plow that came from a truck with a truck mount to a QA? Can the mount be purchased and then welded to the plow? Any help???
/ adapt a plow to a QA #2
I took a fisher truck plow and cut it off where it mounted to the truck ( in front of the pins) and welded it to a skid steer blank plate. Ran some new hoses and a couple restrict or valves. It works great. I have seen other guys weld bosses and pin a plow on and use a chain to lift it. But welding it solid allows me to get down pressure when plowing hard packed snow.
/ adapt a plow to a QA #3
this is how i did mine
/ adapt a plow to a QA #4
There are several ways to do this,first thing is to purchase a blank SS adapter plate.Mine floats with a chain.If I were to do it again I would shorten as much as possible.
Very interesting Thanks
Hey, is that a Britiany. I had 1 a long time ago. I think maybe its time. Great dog
/ adapt a plow to a QA #8
I am going with an old Speedcast style, the old Fisher conventionals. The good thing about those is no pump/light/headunit like the newer MinuteMounts, just a blade with pistons and A frame. Plus e blades themselves are becoming a dime a dozen up here as no one runs the old ones much anymore. 70 bucks got me a 7.5' blade that needed a tiny bit of welding.
I have been planning it in my head all year and was convinced to mount the blade as far back as possibe but changed my mind recently. My tractor will not be the primary plow, I have two trucks for that. What the tractor will do is push piles further than the truck and knock down the walls build up by the truck. For that reason, I will be going with a SSQA plate and welding a Speedcast pushbar to it. I actually want the plow out far to push snow dwnhills or off driveways. Something to think about when designing.
/ adapt a plow to a QA #9
When converting my dads we welded the QT plate flat on the A frame for the plow. This allows him to lift the blade vertical to make more room in his shed. I'll post pics if I can get over there soon.
/ adapt a plow to a QA #10
No,it is an orange and white Elhew English Pointer.They also come in black and white and liver and white.We have had all three.We see all kinds of dogs on our preserve including Brittany's.
Wow,$70 for a 7.5. Down here I just went and saw a plow for$200 and it was rusted through in 3 places. I did just finaly get one. $400 for a 6' old jeep plow and a frame that looks likee **** but is sound. Needs 2 cly QA ect. I'm thinking $800 to bring it new. Thats CT for you
Wating for the pics........E
/ adapt a plow to a QA #13
Haven't gotten over there yet. Sometimes life just needs to slow down and realize I have things to do.
/ adapt a plow to a QA #14
Sorry about the weeds. Best I could do for now haven't had to use it yet.
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59912)
2019 HYUNDAI...
Bulk Lot - (10) 8in x 20ft Fat Lip Pump Hoses (A63689)
Bulk Lot - (10)...
2012 CATERPILLAR 259B3 SKID STEER (A64279)
2012 CATERPILLAR...
2019 Volvo VNR64T T/A Sleeper Cab Truck Tractor (A61573)
2019 Volvo VNR64T...
2015 Honda Accord Sedan (A61574)
2015 Honda Accord...
2011 Peterbilt 6x4 Water Truck w 52,000 GVWR, and 2,000 Gallon Tank (A63689)
2011 Peterbilt 6x4...
