Quick Hitches What kind of quick attach is this?
   / What kind of quick attach is this?
Many thanks Steve, pretty much solves the mystery. Thought I got a sweet deal on the TT75A but think after upgrading to SSQA won't be so sweet:-( Also think the longer we wait the more attachments will wind up 'slightly modified' to fit only that machine. Likely we will wind up with a skid steer in the near future so guess its time to take the plunge and order the proper bits, ouch. Not looking forward to explaining that one to the misses/accountant!
   / What kind of quick attach is this? #12
Is it a New Holland loader or an aftermarket? A loader make/model number would be helpful if you have that info.
Travis
It looks like the SSQA kit would set you back + $2.8K. The fact that Travis did not recognize your setup tells me that attachments that use that setup must be scarce and thus probably a lot more expensive than those using the SSQA design.
I say go for it -- your loader isn't going to be of any use if you can't attach a bucket, forks, etc. Regarding the Missus, I've found after 45 years of marriage that asking forgiveness rather than permission works. Well, at least sometimes.:)
Steve
   / What kind of quick attach is this? #14
   / What kind of quick attach is this? #17
I think this kit is designed to convert pin-on buckets. The manufacturer is a member here -- see http://www.tractorbynet.com/forums/attachments/270316-quick-attach-conversion-kit-need.html.
Steve
From the link you posted, they do have the conversion kit. I bought one and made an adapter out of it so I could use SSQA on my JD 640 loader.
By adapter, I mean I put it on the JD 600 series Quick Attach then can use SSQA attachments. Take it off and I can use JD 600 series attachments.
OP could buy one and bolt or weld it directly to his loader's current mount and then use SSQA attachments.
   / What kind of quick attach is this? #18
Yours come stock? New Holland claims they don't have specs...
I bought the tractor in 2005, and it's a 1993, so I don't know if it was stock. PO was a Ford tractor sales guy, so might have got something others couldn't??
I did have an adapter welded up for my grapple, but the bucket and snowplow were already adapted to the QA. My loader is a 7109, don't see too many on this site.
Jim
2010 Ford Fusion Sedan (A53424)
2010 Ford Fusion...
A45G DUMP BED (A55745)
2003 PETERBILT 330 DUMP TRUCK (A55745)
2003 PETERBILT 330...
2000 WINNEBAGO FORD F550 RV (A55745)
2000 WINNEBAGO...
Toro Workman Low Profile Spray system 200 (A50322)
Toro Workman Low...
2024 KMC 7406 (A53084)
