ktm250rider
- Joined
- Oct 7, 2004
- Messages
- 236
I have similar issues with mine too. Any update on fixing? I figured on replacing the clutch plate.
or how that would ever crack like that.Well showed to my neighbor and he says its not a crack Its the end of the spool that was welding to the sides and then machined smooth. Lots of weld left on the inside where the wire wrapped. He thought the spool was rusted too much and may not get a solid engagement on the friction plate.
His suggestion was to sand it as best I can . Clean up the pads and try it . If it works better take itv all apart and go to a machine shop and have them lathe the plate smooth again. I don't want to remove much as the friction disc is 10 MM and replacement is 7 MM. I did price the pads and are $60 ea X 6 plus rivets.
I have cleaned up the plate and pads seems to pull better but have not had the opportunity to pull a heavy pull yet.
n
I used Emmery cloth to remove the crap from the pads. The pics don't show the area where the pads ride. but as you say its not a flat surface there either. The seller told me that he didnt use the winch for 4 years since he bought his skidder. and it was sitter in an orchard for 4 years not covered. I will remove the plate and have machinedWhat did you use to clean the pads?Also your pics, what exactly are you showing us? All I can say from looking at the surface is there is a lot of rust and wear and what appears to not be a very flat surface from the outer edge of the big hole for some distance across the worn area and then, near the top of pic # 2 the gap between the shiny surface and the rest of the darker portion of the disk. If what you're showing us, the shiny rough area, is where the clutch pads are supposed to contact to pull the cable it should be perfectly smooth, or have a machined crosshatch pattern to grab the clutch pads securely to effect proper friction and allow the cable to pull it's intended load. IMHO, without the necessary smooth AND FLAT surface you will not be able to achieve the winch's potential pulling power. This may be why it was for sale? If by cleaning/sanding the pad contact surface and thoroughly cleaning the pads you achieve significantly more pulling power then you are on the right track and should consider having the surface machined, at a minimum. Again, just my opinion, but that's what I would consider if it were my 'wench'.![]()
