Question about e-scv
/ Question about e-scv #1
corey9212
Red Deer County, AB
2015 John Deere 3046R
Hello, I have a hydraulic top link for my tractor and when hooking up I find I am constantly in and out of the cab to adjust the length to get it hooked up. I was wandering cause it's an e-SCV is there a way to install a two way toggle switch on the rear fender (or use one of the two lift arm switches instead) and splice it into the SCV switch in the cab so I can operate it from the outside as well as inside?
I do know you can buy a factory hydraulic top link for this tractor that is plumbed into the hydraulic lines and can be hooked up from inside the cab but I imagine that would get expensive so I am hoping there is a way for what I'm describing to work.
Thank you.
Easiest thing would be to just get a 3pt quick hitch. ;)
I have thought about that but the problem is all my attachments vary between cat 1 and cat 2 and my 3pt hitch is a cat 3, got lots of bushings laying around, lol.
/ Question about e-scv #4
:eek: you use a cat 1 implement behind a tractor that has a cat 3 hitch. :eek: I sure hope that the implement NEVER touches the ground.
You could do a lot of modifications and use cat 2 for everything. ;)
Good luck
/ Question about e-scv #5
You can certainly wire a switch in parallel so you can control the SCV from two locations, this is actually standard on some larger tractors. You will probably need a DPDT center off switch thats momentary in the two ON positions. I would need to look at the schematic to help any further.
:eek: you use a cat 1 implement behind a tractor that has a cat 3 hitch. :eek: I sure hope that the implement NEVER touches the ground. You could do a lot of modifications and use cat 2 for everything. ;) Good luck
Technically all my attachments are cat 1 but most had their lift pins converted to cat 2.
Sweet, it wouldn't be hard for me to find out what wires go to the cab switches then tap into them. I just wanted to make sure it was possible and would work before I attempted it.
/ Question about e-scv #7
As I am sure that you know, just by changing the pin sizes does nothing to change the implement to a cat 2 implement. The implement is still a light duty implement with the wrong pin spacing. My point was that ANY cat 1 implement that touched the ground was most likely going to be a light duty implement for your tractor. Even if it was considered a heavy duty cat 1 implement, it is still a light duty implement for your size of tractor. ;)
Yes I am aware of that, I have had to be very careful with them and going slow so I didn't wreck them. Most of them were sold to me by my dealer at the time when I bought a 5115M (cat 2 tractor) I would like to upgrade to more appropriate attachments but will have to wait till I pay off the payments from what I have already.
/ Question about e-scv #9
I am surprised that your dealer sold you anything cat 1 to go behind the 5115M. :sigh: :no: It's not like you had bought a 50hp cat 1-2 machine. I'm sorry, but this just puts another bad mark for dealers on my list or why you don't trust dealers. :(
Yeah it was definitely a strike against my trust for dealers but the whole deal with the 5115M was just a big mess, all I can say is he should have definitely sold me cat 2 attachments instead of cat 1 and saying they are big enough for the tractor. The new dealer that sold me the 6125R is trying hard to get my trust back and so far he has given me no reason to not trust him but understands me being leery and questioning some of what he says.
/ Question about e-scv #11
I know that when I bought my first new tractor with some implements, I caught my dealer selling me stuff that was not rated for my tractor. Unfortunately I only caught some of the stuff and the rear blade and landscape rake got by. Honestly I just didn't know any better. :ashamed:
When I bent the rear blade THE very first time that I used it, I called the dealer about it. I was told that I must have abused it and that it would not be covered. I didn't even bother to call on the landscape rake that looked like a Churro. :( That was the type of service that I got after spending $45K with them. :thumbsup: :thumbsup: :rolleyes:
Not any wonder that they went out of business. The saddest thing, I think that they didn't have a clue that they actually sold me the to wrong duty units. :sigh:
I know that when I bought my first new tractor with some implements, I caught my dealer selling me stuff that was not rated for my tractor. Unfortunately I only caught some of the stuff and the rear blade and landscape rake got by. Honestly I just didn't know any better. :ashamed: When I bent the rear blade THE very first time that I used it, I called the dealer about it. I was told that I must have abused it and that it would not be covered. I didn't even bother to call on the landscape rake that looked like a Churro. :( That was the type of service that I got after spending $45K with them. :thumbsup: :thumbsup: :rolleyes: Not any wonder that they went out of business. The saddest thing, I think that they didn't have a clue that they actually sold me the to wrong duty units. :sigh:
I'm glad I'm not the only one with that kind of dealer problem but I'm not glad that dealers take people like that and then say they did nothing wrong and that it's the users fault, my story is almost identical to yours, just with different attachments getting wrecked. From what I've been hearing this dealer might not be far from being bankrupt as well (maybe that's why their prices are so high, trying to make as much as possible as quickly as possible before bankruptcy happens.)
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A64278)
KNOW BEFORE YOU...
2015 PETERBILT 567 TANDEM AXLE DAY CAB (A66091)
2015 PETERBILT 567...
2022 Mercury Verdado 300HP Outboard Boat Motor (A64557)
2022 Mercury...
2003 PETERBILT 379 SLEEPER (A59914)
2003 PETERBILT 379...
2026 MACK GRANITE GR64F DUMP TRUCK (A63276)
2026 MACK GRANITE...
2005 International 5900i T/A Gardner Denver Kill Truck (A64194)
2005 International...
