2615 Oil Leak
/ 2615 Oil Leak #1
North Ga.
Mahindra 2615
I have a 2615 that is seven years old. I have a hydraulic oil leak. I believe it is coming from where the gear lever housing attachs to the transmission. When looking from underneath there is oil on the bottom of the transmission housing. There is no oil on the filter housing.
I am wondering if anyone else has had this problem.
Butch
/ 2615 Oil Leak #2
I have a 2006 2615 and I have not had that problem, but I am interested in what it is and how to fix it. I can't look at mine right now but is there a hydraulic line going there?
/ 2615 Oil Leak #3
Butch
I've had this happen a couple of times. It turned out to be the banjo fitting on the left rear side of the tractor; underneath the operator's station. If your leak is coming from the same fitting, you'll need either a 22, or 24mm wrench, or a long crescent. I use a crescent wrench which is just slim enough, and long enough to apply some leverage.
/ 2615 Oil Leak
AchingBack. I checked the bango fitting and is dry. The only spot with fluid on besides underneath is on and around the gear sift lever boot.
Butch
/ 2615 Oil Leak #5
Butch
Okay, I misunderstood. It sounds as if you have a gear tractor. The HST will be totally different. I hope it is simply a loose fitting.
/ 2615 Oil Leak #6
Have you changed or added hydralic fluid to your tractor lately? If so it could just be over full. I did this once .
/ 2615 Oil Leak #8
I am having a similar problem. I believe mine is coming from a plug that has worked it's way out possibly due to a plugged vent? #13 in this pic.
/ 2615 Oil Leak
I am still having this leak on my tractor and I am wondering if Part number 14 is a gasket and this is where my leak is.
Any ideas would be of great help.
Butch
/ 2615 Oil Leak #13
Did either of you solve the leak? I am having the same problem with my 2615, leaking from the top plug in the illustration. Thanks
/ 2615 Oil Leak #14
Butch
Hey Butch, I'm having the same problem with my 2615, what did you figure out?
Thanks Marty
/ 2615 Oil Leak
I have been told that there is no gasket where the shifter housing meets the trans housing. It uses a gasket sealer. I would like to no from our dealer friends if that is true.
Butch
43024 (A59228)
43024 (A59228)
2006 Dodge Grand Carvan Van (A61574)
2006 Dodge Grand...
John Deere 6200 Tractor (A64047)
John Deere 6200...
Mini Excavator Rake Attachment (A61572)
Mini Excavator...
Pemberton Inc Komatsu Forks and Frame (A64194)
Pemberton Inc...
Hydraulic Breaker Excavator Attachment (A59228)
Hydraulic Breaker...
