2006 New Holland TL100A steering
   / 2006 New Holland TL100A steering #1
ft52
Fayetteville Tx
2006 NEW HOLLAND TL100A, 1986 John Deere 2150. 1954 Farmall Super H Stage 2 .1964 Farmall cub. 1948 farmall cub. 1941 Farmall B
Steering wheel does not stay in same position when steering. Steering wheel turns but tractor wheels do not turn the same at some times when turning to the right.
Thank You.
   / 2006 New Holland TL100A steering #2
All my NH's do the same thing. Left or right turns do not matter. If you do a full turn, the steering wheel does turn further. Why I don't know. but it doesn't bother me.
But if your steering is doing some strange, then check the steering cylinder. Maybe something is wrong?
   / 2006 New Holland TL100A steering #3
One of my 40 series New Hollands is doing the same thing. My best guess is we have a valve problem in the steering control valve. Perhaps a relief valve sticking open. Sometimes by turning slightly back and forth it will go ahead and steer the wheels further around.
ft52
Installed seal kit on tl100a steering cylinder on tl100a. Fixed the problem
   / 2006 New Holland TL100A steering #5
It is encouraging to hear that. Getting at the steering box is no easy task. Thanks for the info.
Thank You.
Installed seal kit in steering cylinder and it fixed it
   / 2006 New Holland TL100A steering #7
I am pleased to hear it. The 5640 doesn't have weights in front, so I made a reciever hitch to go there, and we push the haywagons into the sheds with it. Gets very frustrating when the steering isn't responding properly. I think, if memory serves, that the cab must be removed to get at the steering box.
23018 (A55758)
23018 (A55758)
JOHN BLUE 1000 GALLON NURSE TANK (A52708)
JOHN BLUE 1000...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
2014 VOLVO VHD DAYCAB (A58214)
2014 VOLVO VHD...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
