In cab fire extinguisher mount
/ In cab fire extinguisher mount #1
rallyvt88
Vermont
Massy Ferguson 1540
I have been a lurker for quite a while now but I have finally decided to come out of the shadows. I have learned quite a lot from this site and seen a lot of creative solutions to problems, so I hope that someone may be able to help lead me in the right direction for a project I am working on. I have a classic body (2004.5) Sierra crew cab with a Duramax. I have been looking to install a fire extinguisher inside the cab and I have a few different criteria that I want to fire extinguisher mount to fulfill. One, I don't want to screw the mount directly to anything in the cab. I do not want to run the risk of rust, chance water leaking into the cab, or ruin any trim pieces. Two, I want it to be accessible from the driver seat, i.e. not stashed behind the rear bench. And three, I don't want it free, rolling around in the back. I have done a number of searches, but I have yet to turn up anything that fits what I am looking for. For those of you that do have fire extinguishers in the cab, where do you mount them and what did you mount them with? I plan on running a 2.5 lb bottle, the 5 lb bottles look way to big to be put anywhere inside without taking up valuable space. The truck has a front bench so I was thinking that I may be able to utilize some of the space over the tunnel. Has anyone seen creative mounting ideas?
/ In cab fire extinguisher mount #2
Welcome,..I've used industrial Velcro for light things like that. If you have carpet on the tunnel, that might be a problem.
/ In cab fire extinguisher mount #3
I would not call a fire extinguisher light. I had a good friend of mine hit black ice and then a concrete barricade in a K5 Blazer a number of years ago. He had a 2" trailer hitch ball laying behind the rear seat, just the ball. It actually went through the dash and dented the firewall on impact. He also had a wheel stud and lug nut in the cup holder that blew through the front windshield.
Not that this is the same but the spare tire was just laying on the floor behind the rear seat. It broke the rear seat back off and pushed the front passenger seat forward breaking the seat track into the dash. If his wife or one of his kids would have been in that seat they may have been dead or seriously injured.
Any of them items could have killed him. A 2# chunk of metal like a fire extinguisher going from 60 to 0 instantaneously is like a cannon ball.
Something to think about.
I would mount it or just forget it.
Chris
/ In cab fire extinguisher mount #4
Chris
Mounting it to the transmission tunnel as the OP stated would mitigate that. If it got loose it would have about 4" to move in a collision, either way. Industrial Velcro is pretty strong stuff. I wouldn't mount it with Velcro at head level or 4' away on a floor...Just following the OP's question about the transmission tunnel mounting option without drilling holes. If that's a problem, I guess I could be killed my full coffee mug in my cup holder....Just kidding, I get your point.
/ In cab fire extinguisher mount #5
I actually never thought about this until my buddys wreck. I saw the truck first hand at the junk yard afterwards. I was amazed at the internal damage from the items I mentioned.
In all seriousness its unlikely to kill you but even a coffee mug or a can of unopened soda could in such a accident.
Chris
/ In cab fire extinguisher mount #6
Chris
I know, but the OP sounds like he has a regular cab pickup. Yes things can fly, but mounted to the trans tunnel gives no real fly room. If it did, the problems would be more than the fire extinguisher could cause. In the K5 example, I agree, but that's not the case here.
Then again, I don't bolt my WD hitch and associated parts to my truck bed when I go to my camper to bring it home or take it to it's spot, now that would leave a mark.:eek:
I have the emergency beacon on my RTV mounted to the roof with Industrial Velcro. It has never moved, slamming snow banks and even on my trailer. It's not the Wal-Mart stuff. Takes 2 hands to remove the beacon and it ain't easy.
Option-- a couple of short, self tapping sheet metal screws could mount it to the tunnel without causing any problems. I did this to place a brick style cell phone mount to the tranny tunnel in my Suburban in the mid to late 90's. No leaks or issues. When I sold it, I removed the mount and couldn't tell it was even there.
The Velcro is a possibility, but I would like something that looks good as well. I also don't want to be in a situation where I need the extinguisher and I need to use both hands to pry it off of the floor. It is a crew cab truck with carpet over the tunnel. I was recently at a car show and I saw a Porsche 911 with a fire extinguisher mounted in front of the passenger seat with the mount bolted to the seat rails. I have been looking for something similar but have struggled to find something that may work in a truck. I am also concerned about limiting my seat travel if I mount anything directly to the seat rails as well as kicking the thing every time I am getting in or out of the truck. Here is an example of what I have seen on some other vehicles.
Fire Extinguisher and Mount Package - Power Seats-Rennline, Inc.
/ In cab fire extinguisher mount #9
Make your own or modify a purchased one.
Chris
/ In cab fire extinguisher mount #10
Chris
that's a good reminder of something everyone should know but most dont think about until it's too late. Thanks for mentioning it. I'm bad about having loose objects unsecured in the cab.
/ In cab fire extinguisher mount #11
Buy a fire extinguisher with a mount...All you have to do is un-clip the straps to release it, the mounting hardware is irrelevant.. Had one of those in my Chevelle.
/ In cab fire extinguisher mount #12
Sew a bag that fits the extinguisher with material the same color as your upholstery and add straps to attach it to the seat frame. Fas-tech fasteners like on backpacks or quality mountain gear.
/ In cab fire extinguisher mount #14
What type of extinguisher - Dry Chem or Halotron? Halotron is more expensive but recommended for vehicles.
/ In cab fire extinguisher mount #15
I recommend a six pack of cheap beer.
I was driving a car one day and the owner had taken the air filter off. The car backfired through the carb and caught fire. I called for a fire truck but before they got there I had located a six pack in the rear floor board and shook one up and popped a top and the fire was out before the firetruck got there. After a few minutes the thing started right up and I drove it straight to the jail.
/ In cab fire extinguisher mount #16
I saw a car at the drag strip backfire through the carb (something Chevys are famous for) when he went to do a burnout. It had a cowl hood on it and you could see the fire. The car was a pretty fast car, it had a roll cage and a 6 point harness. The guy working the burnout box did not know what was going on and the driver was trying to get out out the car. A guy walked up with a big lemonade and threw it under the cowl hood and put the fire out. The guy started the car back up and ran it.
/ In cab fire extinguisher mount #17
Lemonade would certainly work. :thumbsup:
I think the beer worked good because of the foam.
/ In cab fire extinguisher mount #19
Don't some fire extinguishers shoot foam?
I think some do. That was the one and onlt time I've ever needed a fire extinguisher around a vehicle.
I did see one burned to the ground on the side of I35 the other day. Fire trucks still there but it was a crispy critter. Caused a big traffic back up too.
I recently bought a 2.5 lb ABC extinguisher with a mounting bracket included. It would be nice to figure out a way to attach a mount using some of the existing hardware and attach the fire extinguisher bracket to that. I have been throwing around a few ideas with a friend of mine who is a fabricator. Hopefully I can articulate what I am after and let him take care of all the welding. If the first try doesn't look like a pile of scrap, I will make sure to post pictures. Thanks for the help so far. I think I will try and stay away from the beer and lemonade method so I have something to drink when I get home.
JOHN DEERE 9420R ARTICULATING TRACTOR (A65057)
JOHN DEERE 9420R...
2015 CHEVROLET SILVERADO CREW CAB PICKUP TRUCK (A66091)
2015 CHEVROLET...
TEST YOUR BID BUTTON! (A65056)
TEST YOUR BID...
2013 C&M TRAILER CHLORINE DIOXIDE MANIFOLD TRAILER (A67714)
2013 C&M TRAILER...
2004 (INOPERABLE) INTERNATIONAL TRANSTAR 8600 (A67714)
2004 (INOPERABLE)...
PALLET OF 51 X 41 X16 BRASS WEAR RINGS (A68842)
PALLET OF 51 X 41...
