John Deere 4840 Alternator
/ John Deere 4840 Alternator #1
NMCCOY1063
Scott, Arkansas
JD4840
Battery has been charged. Alternator rebuilt. Tractor want start without jump. Regulator show overcharge in cab when switch turned own.
/ John Deere 4840 Alternator #2
Have you cleaned and tightened ALL battery cable connections?? It's also possible that you have a battery cable corroded under the insulation. If cables are good then I will guess you have one or more bad batteries.
/ John Deere 4840 Alternator #3
Are you saying gauge in dash shows overcharge without engine running? Try checking voltage with a voltmeter at the alternator both without engine running and with engine running. Gauge seems to be not working in dash. If alternator is not charging, be sure to check wiring. With key on, there should be power to all three wire connections.
2007 Chevrolet Silverado\ Silverado Classic Pickup Truck, VIN # 1GCEK14X27Z181945 (A61165)
2007 Chevrolet...
2018 CATERPILLAR D6T XL HIGH TRACK CRAWLER DOZER (A62129)
2018 CATERPILLAR...
429782 (A61165)
429782 (A61165)
John Deere 1025R (A62177)
John Deere 1025R...
2014 Chevrolet 2500 Savana Van (A63116)
2014 Chevrolet...
New/ Unused Plate Compactor (A61166)
New/ Unused Plate...
