Core Aerator
   / Core Aerator #1
Frank Sorbello
Gold Member
Power Trac PT-422
I purchased a core aerator (used) this summer. I tried it today. It isn't throwing plugs. I cleaned all of the holes and tried again. It just plugs and stays plugged. I tried it at different speeds and different heights with same results. Ground is soft and loamy.
   / Core Aerator
yes, it is pt aerator. Not sure why it isn't throwing the plugs.
   / Core Aerator #4
It could be that the ground is too soft. That will sometimes causes the tines to plug up.
What kind of depth are you getting with the PT aerator?
   / Core Aerator #5
Two years ago I was thinking about buying the aerator attachment for my PT 425. I watched the PT video on the attachment. It did not seem to be pulling up plugs. I asked a PT rep if it could pull up 4 inch plugs as most aerators. The reply was that I would have to add weights to the top of the unit. I did not purchase it. The top of the attachment is smooth and slightly tilted. Some sort of weight bar or other mechanism would have to be wielded on the unit to hold weights or concrete blocks. I doubt if downforce can be applied with the arms because float mode would be needed to traverse an uneven lawn.
   / Core Aerator #6
I was skeptical about the performance due to the tine layout on their aerator. They have all of the tines in a row which you never see on purpose built aerators. Normally they are staggered so you don't have as many tines in the ground at the same time.
Does anyone happen to know the weight of their aerator?
   / Core Aerator #7
Frank, if the ground is soft and loamy, it probably doesn't need aerating. I think what is happening is your pluggers are just pushing into the ground and the ground itself is not firm enough to push the plugs of dirt up and out of the top of the pluggers. Its just squishing the soil down.
   / Core Aerator #8
I mentioned in another thread that I think they are staggered, they are just lined up pretty in the picture. It appears each wheel of pluggers is independent on the shaft. Otherwise, you could not turn the unit with the pluggers in the soil. It would trench. I could be wrong, though.
   / Core Aerator #9
My thoughts exactly :)
   / Core Aerator #10
I have the core aerator from PT and love it. I always get a 3 inch plug and do not have to use any weights. The down pressure of the arms is enough to get great results. I core aerate in the Fall and leave the plugs to break down during the winter. I have found that the ground should have a little moisture in it.
PJ
   / Core Aerator #12
PJ
Are you able to make gradual turns with the tines in the ground without tearing turf?
   / Core Aerator #13
Yes but gradual only. I usually lift, reposition and start new. A long gradual turn is no problem.
PJ
   / Core Aerator
Any one out there with either a 422 or 425 have the core aerator? I played with mine again today. Can not get it to throw plugs. Tried all types of ground.
   / Core Aerator #15
Can you tell if it is penetrating the dirt fully? Often that is a issue related to not having enough weight to force the core cutter into the ground and push the last plug out.
   / Core Aerator
The pluggers go in the ground maybe an inch or so. Don't know how I can add weight to the aerator the way it is designed.
   / Core Aerator #17
That is your problem - as the core cutter goes down it presses out the last plug. (I don't know what yours looks like - sorry)
Two things help, one is weight and the other is soft ground. If the ground is too hard it stops it from penetrating and clearing the last core out. If you can't add weight, timing your "plugging" becomes far more important.
I am looking for a 3pt model currently as the area I am doing is too darn large for the walk behind and most of the ones I personally like run over 500lbs for a 36" model to give you some idea.
   / Core Aerator #19
PJ
Frank,
As PJ (RIP PJ :) ) mentioned in this post back in 2013, his worked well with down pressure.
Have you tried down pressure?
And, what type of soil do you have? Is it hard or soft to begin with?
   / Core Aerator #20
Also, as you mentioned you watched this video, you can see the operator changing down pressure as he goes. What you don't see in the video is any close-ups of the results.... plugs laying on the surface of the lawn after he passes.
2021 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A52709)
2021 CATERPILLAR...
2021 Billy Goat F902H Walk-Behind Debris Blower (A59228)
2021 Billy Goat...
2020 INTERNATIONAL REEFER TRUCK (A58214)
2020 INTERNATIONAL...
2011 CATERPILLAR 279C SKID STEER (A60429)
2011 CATERPILLAR...
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A56436)
Galvanized...
