Request for Info Husq 455
/ Request for Info Husq 455 #1
Avondale
Apple Hill, Ont
Kioti DK35 and Kioti NX6010
Hi
I broke the plastic chain brake handle. Is this as simple as swapping it out or will it activate the brake when I unscrew it? Will I need any special tools or knowledge if the brake shifts while changing the plastic part? Any help would be appreciated.
/ Request for Info Husq 455 #2
When you broke it did it end up in the brake locked position? That is the hard thing to undo without the whole handle to provide the leverage. If it's unlocked so the saw can spin the chain it shouldn't be a problem. How did you break it to begin with?
Yes it did but I managed to unlock by prying up on the remaining stub with my spark plug wrench. The chain spins freely. It broke when my Mrs. backed our wood trailer into it. I should have been more careful where I left it as I was the one who told her where to park the trailer.
/ Request for Info Husq 455 #4
Chain brake on my 455 gave up the ghost long ago. I just left it out because it was not cheap to replace.
/ Request for Info Husq 455 #5
You should just be able to remove the handle and replace it. Fairly easy proposition if you're handy at all. If not, see a dealer. I would advise against running it without the brake, it's there for a good reason.
Sent from my LGL35G using TractorByNet
/ Request for Info Husq 455 #6
I can see you like sleeping indoors.!:laughing:
/ Request for Info Husq 455 #8
Seen $30 new shipped. Didnt see any used ones still in stock in my honey holes. :licking:
/ Request for Info Husq 455 #9
I only have one saw with a chainbrake, and I dont run it that much. I personally feel that the (mostly flase) sense of safety the brake gives you makes you more slack in safety. I always find my sef taking fewer shortcuts running the old pioneers.... I guess the thought of you having nothing to stop it if something goes wrong makes you automatically work safer...
Of course, if you dont run a saw much, I highly recomend one...
I guess what Im saying is that although I wouldnt remove a working one, I wouldnt rush to fix a broken one...
2021 CATERPILLAR 745 OFF ROAD DUMP TRUCK (A62129)
2021 CATERPILLAR...
New/Unused AGROTK 72in Quick Attach Brush Cutter (A65583)
New/Unused AGROTK...
2003 Kenworth W900 L Model (A62613)
2003 Kenworth W900...
2023 Top Air ATV 200 Gallon Pull Type Sprayer with 30ft Booms (A63688)
2023 Top Air ATV...
2008 WELLS CARGO 16 ENCLOSED T/A TRAILER (A65643)
2008 WELLS CARGO...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A65643)
2020 TROXELL...
