Would like honest suggestions about tow vehicle issues
   / Would like honest suggestions about tow vehicle issues #61
So, used diesels it is. What I don't get, is with the HP race in trucks why someone doesn't get honest and build a stroker engine, with HP in the 300+ range and torque well above 400, but starting at say 1500 and peaking at 3000 rpm or so. Maybe 3500. It can be done, but I think the numbers strat sounding sexier with higher rpms and thats what the ad companies use to sell. Very sad.
Maybe I'm not reading your post right, but most of the diesels make much of their power way down low where it's needed. All of the Cummins make their peak hp at 2500-3013 RPM, depending on year, and their peak torque at 1500-1600 RPM. For example, my '05 makes 325 hp @ 2900 RPM (auto trans.) and 610 lb-ft @ 1,600 RPM, all stock. All very usable power right where it's needed. Is this what you're referring to?
Joe
   / Would like honest suggestions about tow vehicle issues #62
My 2007 2500 duramax crew cab Sierra SLT now has 157,000 miles. Oil changes, diesel fuel filter changes, initial tire replacement at 107,000. I haul everything from my tractor to my wife's Yukon XLT on my 20' trailer frequently crossing the Berkshires on rte 90 and have been happy since I bought it in 2007( new body stile). No rust, just replaced mixing door actuator for driver's side heating/AC. Did Titan upgrade to 55 gal fuel tank ( Stock 24 gal was a joke!). Everything else remains stock. Drivers seat raise/ lower height adjust broken in "up" position. Replaced 4 burnt out headlights. Mileage 16-24 based on use, mostly speed!. Most dependable vehicle I have ever owned. Just my experience, hope you can do as well or better with your next truck.
How did you get 100,000 miles on tires? I have had 6 2500 and 3500 trucks, all 3 brands. Never got more than 40,000 miles on any. I rotate every other oil change.
I do use my trucks as intended, not so much as a daily driver. About 70% of the miles are towing or hauling.
Chris
   / Would like honest suggestions about tow vehicle issues #63
I have no doubts there are lemons, like Diamonds neighbor. I bought a new GMC Sierra, in 2006. Worst vehicle I ever owned. It went back to GM on the CA lemon law. Got my money completely back and bought the Tundra. By comparison the GM was in the shop 12 times in the 8 mmonthsI owned it. Got the Tundra in late '06, and it has never been to a repair shop. Never needed to.
seriously if Toyota were coming out with the rig Nissan has announced, I would probably figure out a way to buy a new one. No way do I want to go gas again. I want the power without going to 4000 rpm to get it.
Emissions. Big blocks and strokers cant meet the current ratings with the technology avaliable.
Chris
   / Would like honest suggestions about tow vehicle issues #64
My $.02...... I own a 03 dodge Cummins that gets 13 to 14mpg towing a 10,000# fifth wheel. It has been chipped and as far as the engine goes is very reliable, but had to replace the transmission 2 years ago. A friend of mine owns a 01 f350 with the 7.3 and loves it but can't seem to get any fuel mileage out of it. My dad owns a 06 or 07 Chevy diesel loves the truck but couldn't get milage until he chipped his about a year ago. So my opinion would be that if you want fairly stock power milage and reliability go for a pre emission duramax with the Alison and chip it for milage. Remember this is coming from a dodge fan.
   / Would like honest suggestions about tow vehicle issues #65
Sure enough, 107,000 mi on Bridgestone Duravis commercial tires. I do rotate tires with each oil change. My Sierra 2500 diesel is my daily driver, and easily 90-95 percent of mileage has been and continues to by highway, occasionally towing but rarely loaded with more than 500-600 lbs.
I was so happy with the Duravis mileage, that I held out for exact replacements despite the tires having been unavailable/ on back order for a couple of months despite needing them badly. No belts visible but with very little tread left when replaced. Replaced just in time for the coming fall season two years ago, 50,000 miles ago!
As you can see, have lost only the most superficial water sipping grooves on large lugs. Pricey at over $1300 for a full set, but with my current set duplicating my previous wear rate, I reccomend them highly!
Joe
No you didn't quite get it, my syntax is to blame though. I was referring to gas engines when I was describing the power, not diesels. Sorry bout that.
I believe the '06-07 Dmax was where I was headed. Seems to fit the bill well for my taste and needs. Thanks for the chip-update info though.
Recommended chips? Not looking for huge power gains, more interested in mileage and reliability.
OK refresh the memory of an old man. What was wrong with the '05 Dmaxes? Was it mainly that the 6 spd came out in '06? Was there anything wrong with the '05's?
Around my neck of the woods all the 05-07 models seem to have at least 150K on them.
I found a nice '05 for a little over 16K, didn't buy it yet, but it got me wondering about the '05 models.
   / Would like honest suggestions about tow vehicle issues #70
05 like I had came with a smaller cooling system, smaller air intake system, and less power. I had overheating issues pulling more than 12,000#. This is a known issue with pre LBZ motors. I would skip it.
The 6 speed was a big improvement also.
Chris
2007 CATERPILLAR 930G WHEEL LOADER (A51242)
2007 CATERPILLAR...
New Power Line 400 Plastic 3pt. Spin Spreader (A50774)
New Power Line 400...
2020 Case TR310B Skidloader (RIDE AND DRIVE) (A50774)
2020 Case TR310B...
71053 (A49346)
71053 (A49346)
2007 FREIGHTLINER COLUMBIA SLEEPER (A51222)
2007 FREIGHTLINER...
UNUSED CFG Industrial MH12RX Mini Excavator (A47384)
UNUSED CFG...
