Rear Hydraulics
/ Rear Hydraulics #1
powerscol
SW Colorado
CT 235
I want to add rear hydraulics to my CT235. Does anyone know the correct Bobcat part number?
Thanks
/ Rear Hydraulics #2
Sorry that I don't have the part numbers,:ashamed: but be sure to get at least one of those valves with the float function. ;)
/ Rear Hydraulics
What would I use the float for, and do I need the single or double unit?
I know little or nothing about these, so any advice is helpful.
/ Rear Hydraulics #4
Bobcat does not offer a float option on either rear valve, and memory is correct Kioti does not on the comparable CK. Part number for the 2 (dual) valve kit is 7150493. Part number of just the first (single) valve kit is 7150492, this valve has a detent for constant "ON" to run a backhoe or wood splitter. The detent can easily be removed if you prefer "dual action, spring return" on both valves.
/ Rear Hydraulics #5
Kioti does indeed offer a rear remote with the float function on the CK series and not on the DK. This has been hashed out several times. One of TBN members even posted a picture of the decal that goes along the control lever with the float indication on it. Maybe Bobcat doe not offer that option, just assumed that they would since those parts all comes from the same manufacturer. :confused3:
/ Rear Hydraulics #6
Get the double unit. Better to have it and not need it then to need it and not have it. Bobcat and Kioti offer their rear remotes at a very reasonable cost, best to get them with the original purchase in my opinion.
If you plan on getting a hydraulic top & tilt set for your 3pt hitch, (highly recommended for grading purposes) then depending on your ground conditions, it can be nice to have the float function for the hydraulic top link when mowing and or it can be nice to have the float function available when finish grading-smoothing.
Good luck with your decisions. ;)
/ Rear Hydraulics #7
I'm looking at doing the dual remotes without hooking up control by leg I have ct440
/ Rear Hydraulics #8
A double set runs $755 and a triple set runs $890. Either set will have 2 valves with the float function. That is everything to have the valves operational, hoses, fittings, QDs, other than the actual valve mount. :drool: ;) If you want to consider this, you should email me at Fit Rite Hydraulics.
/ Rear Hydraulics
Thanks so much. Do you happen to know the part number for the front remotes.
Also after looking at my unit I am a bit confused where all the levers will go. Next to the rear 3pt list is a long empty slot, and then below that are two empty slots labeled A and C On the left side is a long slot by the PTO that is labeled mid point PTO.
Thanks again for the help.
PS right now I am thinking of one rear remote and a front remote - Thoughts?
/ Rear Hydraulics #10
Not sure if this helps or if you already knew but I just found the parts catalog online on bobcats website
/ Rear Hydraulics #11
Hi,
Today I completed installing a single set of rear remotes on my CT235. It was not a hard job but took me way longer than the "about 1 hour" estimate that was mentioned with the kit. I was not in a hurry and enjoyed the task.
If you have any questions on your install, let me know.
/ Rear Hydraulics #12
Do you want to do factory parts or find the parts from Surplus or Baileynet and do it your self and save big bucks?
/ Rear Hydraulics
I would like to stick with OEM parts for now so everything fits without any modifications. The front remotes has my dealer stumped as they dont show in the parts catalog, unless we are not looking at the right spot.
/ Rear Hydraulics #14
Bobcat didn't list a front kit for the CT225-235 only because of the lower pump flow, but kit for the CT440 will work with some modification to the coupler mounting bracket.
Could also do like I did and run front grapple using 1 of the rear remotes.
/ Rear Hydraulics
Dennis - had not thought of that. Was it fairly easy to do? I could just get the dual rear remote kit and go from there. Was going to start with the single first.
/ Rear Hydraulics #16
Easy enough to do. I ran my hose in 2 sections, so I could disconnect them at the loader mast in case I needed to remove the loader. I didn't use quick disconnects there since I rarely take the loader off, I had my hoses made with male on one end and female swivel on the other for that connection. Tip I learned on TBN - use a garden hose to run where you want the hoses to be, mark the garden hose and measure that length for hoses you need made. 1/4" hose is plenty to run a grapple up there, might want to use 3/8" if there is chance of using a hydraulic post hole digger.
/ Rear Hydraulics
Thanks again Dennis. I have been looking for a front mount post auger, but can only find ones that mount to the bicket with bolts. I have been looking for one to fit a quick attach bracket, but so far no luck. Do you hapen to know of any quick attach ones?
Thanks again.
PS Now I know what to ask Santa for.
/ Rear Hydraulics #18
Bobcat is one I know for sure, but there are others out there. Bobcat sells digger, auger, and mount frame individually. They have a skid-steer QA style and a Excavator mount.
/ Rear Hydraulics #19
So by using the rear remotes is the handles down by right hand leg or did you mount a valve somewhere. Just seems like they would be in the way. Do you have pics of your setup?
/ Rear Hydraulics
I decided to start with the single kit. It's on order. Local dealer gave me a good price with free shipping (If I could wait for their normal order). So next week I will be playing with parts is parts. I just need to remind myself to follow instructions.
New/Unused Landhonor Quick Attach 3 Point Hitch Adapter with PTO (A61166)
New/Unused...
2021 UTILITY VS2DX 53FT DRY VAN TRAILER (A59905)
2021 UTILITY VS2DX...
2011 AUXILIARY POWER UNIT (A60736)
2011 AUXILIARY...
EZ loader trailer (A56857)
EZ loader trailer...
JOHN DEERE 772GP MOTOR GRADER (A58214)
JOHN DEERE 772GP...
2020 FREIGHTLINER CASCADIA MIDROOF SLEEPER (A60736)
2020 FREIGHTLINER...
