Replace PTO Shaft on Ford 501 Sickle Mower
   / Replace PTO Shaft on Ford 501 Sickle Mower #1
macecase
Princeton, KS
1965 John Deere 3020 Diesel and 1975 John Deere 4630 Diesel
I purchased a Ford 501 sickle mower. I was lucky enough to find a parts one as well that somebody gave me for free. So, I have been cobbling them together to make a good, working mower. I feel like I am at that point now but when I went to attach the PTO shaft, I found that it will not telescope. It is frozen shut. Who knows if it was rusted or through abuse became "welded".
So, my thought is to completely replace it. I have looked online and found ways to undo the universal joints. I also see universal joints at tractor supply and whatnot. So, I feel like it should be able to be done but when I look at the one on the Ford 501, I cannot find any snap rings, etc.
I am curious if anybody knows how to dismantle this PTO shaft. I want to completely replace it with the exception of the part that is welded to the mower (by the pulley). So, I would like to keep just that universal joint and put a new shaft on from there.
Is this possible from a practical standpoint? Any other thoughts and suggestions?
   / Replace PTO Shaft on Ford 501 Sickle Mower #2
Look for the snap ring on the under side of the cap.. You may have to do some picking with a screw driver as grease usually is packed around there
   / Replace PTO Shaft on Ford 501 Sickle Mower #3
By the way, I just got a 501 as well.
Ahh, so the part that has SPICER CANADA is just a cap? pop it off to expose the snap ring?
Cool. I am just getting into cutting, raking in baling hay. So, I picked up a 501 at a good deal but it has required a lot of work! I hope your experience has gone well.
   / Replace PTO Shaft on Ford 501 Sickle Mower #6
Mine needs work too. I'll post pics after lunch.
   / Replace PTO Shaft on Ford 501 Sickle Mower #8
Sorry, I missed this post.. No.. I mean the bottom of the cap.. I'll try to find a pic for you.
   / Replace PTO Shaft on Ford 501 Sickle Mower #9
Like this.. you'll have to look from the center of the u-joint.
   / Replace PTO Shaft on Ford 501 Sickle Mower #10
so yeah.. your 501 looks much better than mine.. I initially got mine for mowing around my pond (even though it doesn't go much below horizontal) and it works ok for that... then I decided I wanted to cut hay with it and it didn't do so well.. a closer look revealed why... some of my blades don't even touch the stationary blades.. also, you'll notice that I don't even have the big spring that attaches to the top link.. I can't understand what the purpose of that large spring is.. it works without it.
IMG_20130928_111918[1].jpgIMG_20130928_111905[1].jpgIMG_20130928_111851[1].jpgIMG_20130928_111844[1].jpgIMG_20130928_111829[1].jpg
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A54814)
2014 Peterbilt 384...
2008 VOLVO EC460CL (A52472)
2008 VOLVO EC460CL...
2012 Club Car Carryall 1 Utility Cart (A55851)
2012 Club Car...
2013 Ford F450 4x4 Crew Cab Little Beaver LS300 Drill Rig Truck (A55852)
2013 Ford F450 4x4...
2003 Big Tex 10PI...
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
