Rotary Cutter Woods RM660 making load noises
/ Woods RM660 making load noises #1
Kubota Tee
Gold Member
Hudsonville, MI
Kubota L5740 HSTC-3, Kubota L3540HST-3 (sold)
Was out mowing our 3 acre lot this past Saturday and had just turned to cut another row when my Woods RM660 finish mower started making some loud noises. I immediately stopped mowing and checked to see if there was any interference underneath or if I had hit something. Everything seemed to be in order, but when I re-engaged the PTO, the noise continued. I didn't really have time to dig into it then, so drove the tractor back to the garage and finally got back to it this evening. Here is what I found: image-3993534749.jpg Basically, the idler wheel bearing blew out. I'm actually glad to know that it wasn't the gear box, a blade spindle or something much worse. I pulled out my parts list, found the parts I needed and ordered them up online. Cost me about $85. But then again, it could have been much worse! image-4248165957.jpg Anyone else out there have a similar experience? Same mower? Any inherent problems I should be aware of with this model?
/ Woods RM660 making load noises #2
My RM660 is going on 20 years with nearly 700 hrs. Only thing I ever had to replace were the roller sleeves in the gauge wheels. Still has the original belt. May be the most dependable piece of equipment I have ever owned.
Wow! That is great to know! Have you ever done maintenance on the idler wheel bearing? I checked the manual and couldn't find any maintenance suggestions like repacking the bearings or anything like that. Seems a bit strange that this part should fail.
Thomas
/ Woods RM660 making load noises #4
Thomas
I'm not aware of any maintenance for the idler wheel bearing. Only maintenance I've ever done is greasing the spindles, gauge wheels, u-joints and drive shaft, sharpening the blades, and clearing grass clippings from underneath and off the top of the deck. I have noticed dirt and grass clippings accumulate under the deck guards. I also remove them and clean under them periodically. Did you have any buildup of debris under the guard? Seems unlikely, but maybe debris or an obstruction could contribute to failure of the bearing. More likely you just got a bad one. It happens sometimes. Any idea how many hours on your mower?
No idea how many hours it has since I bought it used. I've had it for 3 years and have put approximately 150 hours on it over that period. I do sometimes get clippings and dirt under the deck guards so perhaps something got lodged into the bearings. I do clean out this area every time I sharpen the blades and grease the spindles. Will have to keep a closer eye on this aspect with the new one.
did you order bearing or pully and bearing
I ended up ordering the pully and bearing together as a sellable unit. Thought this would be easier to deal with from an install perspective.
Everything arrived as I had ordered thanks to the wonderful service at Messicks. They have a great selection of Woods parts and the online exploded diagrams are very helpful. Here are the parts I ordered:
The new idler pully (ordered with the bearing as one piece) installed very nicely and I was able to get the mower working again in no time. I did take the opportunity to do a little clean up as long as I had the covers off.
I still have several weeks left of mowing season, but doing this repair convinced me that I needed to add a couple of "winter" projects to my schedule.
1. Install a compressed air system in my shop with a nice reeled hose near the garage door. This will allow me to easily clean off the mower after every use and hopefully keep the dirt, sand and dust from building up again under the covers. I'm convinced this is what caused the bearing to fail.
2. Since I bought this mower used 3 years ago, I've done very little to it other than keep it greased and the blades sharpened. It's starting to show its age a bit and since I know it is a well built machine with many useful years left, I'm going to do a major maintenance overhaul on it including a very thorough cleaning and new paint job for the covers which are looking pretty rough.
I'll start some new threads on both of these projects once I get them started later this fall / winter.
/ Woods RM660 making load noises #9
Mine too! Purchased it 19 years ago and I have only replaced blades and kept it greased.
MorningView,
Thanks for sharing about your RM660 mower. I have to imagine with a large horse farm, you do a ton of mowing! :cool: Gives me even more reason to invest the time and effort into giving mine a deep "winter" cleaning and some new paint! :thumbsup:
Take care!
/ Woods RM660 making load noises #11
For a while, I was cutting 20 acres every 3 weeks or so for competition riding areas. I still use it to cut around 6 acres every two weeks on specific riding field. RM660 has been a fantastic machine over the last 19 years. I almost sold it once... Glad that didn't happen.
/ Woods RM660 making load noises #12
This past Friday, was welding on some new bolts to hold the covers on the mower, went take the center cover off and found out the bearing was out and the pulley was hanging on by a thread to the bolt.
Ended up just replacing the bearing. It was tough to find, but went to a JD dealer and they matched it up nearest as possible and it all went back together no problem. Needed the inner bushing from the old bearing.
JD part number: gx20818
For Sale L4479 Snowblower and Subframe
For Sale L4479...
Black Jet Dock Drive-On (A59228)
Black Jet Dock...
2019 Ford F450 4x4 Service Truck w/ Tommy Gate (A62613)
2019 Ford F450 4x4...
Okada OKB 304B Hydraulic Breaker Excavator Attachment (A60352)
Okada OKB 304B...
Year: 2017 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 82349 Pla... (A59231)
Year: 2017 Make...
CASE INTERNATIONAL 6088 RWD COMBINE (A63291)
CASE INTERNATIONAL...
