What is Kioti thinking?
/ What is Kioti thinking? #1
Hill Billy Bob
Western NY
2011 Kioti CK30, 2017 Kubota RTV-X1100C, 2005 Cub Cadet LT1050
I've had my CK30 for three years now, and it has never run normal water temperature, always have a piece of cardboard in front of the radiator. (Summer about 33% blocked, winter about 90% blocked) Thinking the sending unit for water temp gauge might be faulty, a few months ago, I installed an engine oil temp gauge, to get a real operating temp. (Being a retired trucker, I like gauges, gauges with numbers) Oil temps ran between 140* and 160*, depending on ambient air temps...this is while mowing for 3 to 4 hours straight.
Yesterday I decided to drain a gallon of coolant from the system, and pulled the thermostat...it was stamped 71*C. That converts to 159.8*F....What is Kioti thinking putting a 160* thermostat in a diesel engine?? :eek:
Did a bit of research on this, and Stant's site to come up with some part numbers... made a trip to local auto parts, and for $7.48 plus $.60 in tax, I came home with a 180* thermostat and a gasket that needed a slight modification to the bolt holes to fit. Installed it, and in about 10 minutes water temp read between the two dots on the gauge. First time ever for this tractor, it will be a much happier engine running in the 180* to 190* range.:)
Stant part # 13848, 180*
Stant part # 13849, 195*
These #'s will work on CK and DK series tractors caling for Kioti thermostat number E5800-73011, or E5853-73011......Bob
/ What is Kioti thinking? #2
Mine has always run between the two little dots, hot weather or cold.
/ What is Kioti thinking? #3
My DK50 sits on the lowest dot - never moves, except for the time my screens clogged. I'm with you Bob, all gauges should be marked with useful numbers.
/ What is Kioti thinking? #4
My DK has always run between the dots. Regardless of time of year or how hard/easy I'm working it
/ What is Kioti thinking? #5
I bet that 160 deg thermostat was put in a few tractors and was not typical of what they normally put it...
Sorta seems like to me they ran out of 180's and got a batch of 160's...
/ What is Kioti thinking? #6
Same for my DK45S (2006 model).
/ What is Kioti thinking? #7
My CK30 stays within the dots, EXCEPT when I am bushhogging tall grass and weeds on dry days. The filters get stopped up and the gauge hits RED. A quick clean out of the filters brings it back to normal
/ What is Kioti thinking? #8
mine has always run between the dots.....no matter when or how i use the tractor.
/ What is Kioti thinking? #10
Mine also runs reliably right in the middle of the acceptable range markers. If it goes up even a smidgin, I know it is time to clean the screens.
/ What is Kioti thinking? #11
My 2004 CK30hst always runs between the dots once warmed up. Because of just dots, I have no idea what the running temp is. I never looked at my thermostat to see what temp it is. I'm more used to gas engines so here is my question. What temp should a diesel engine be running at?
/ What is Kioti thinking? #12
I don't work in a field and never really need to worry about cleaning screens. I've never had anything but dead center of the temp gauge on either my CK30 or DK45. This includes pulling a 8,000lbs trailer over 50KM on a 34C day (30 miles, 94 F). Pulling the load up hills in high range brought back the hot smell from the break in period, but it never changed the reading on the temp gauge.
/ What is Kioti thinking? #13
Mine runs in the factory gauge's 'normal' range. I would prefer a temp in degrees gauge too, and a fuel gauge that actually reflected real level of fuel in tank- not just from full to 'E' when there are still about 5 gallons in the tank. Oh, and while we're jumping forward into the 20th century, how 'bout a reserve light for when one has lets say 2 gallons left?!:confused3::eek: That's not too much to ask is it?
/ What is Kioti thinking? #14
My CK30 took forever, about 1/2 hr, to warm up to the dots a little longer in the winter. My new DK40 seems to warm up to the dots in less than 5 minutes. After the CK, it surprised me how fast the DK warms up. Now you have my curiosity up to see just what temp the DK is running at.
/ What is Kioti thinking? #15
Kioti engineered the engine to use a 160 degrees Fahrenheit thermostat. See manual cut out below. Many small diesels run a low temp thermostats. Just because the thermostat opens at 160F does not mean the head temp is 160F. A cooler engine last longer. There are many factors in determining what temp thermostat is used, such as firing chamber design, metal types, metal thickness, coolant flow, etc. There are almost always two culprits in low temp readings. Improperly working gauge, or improperly working thermostat.
The gauge issue could be caused by the gauge itself, faulty wiring, or faulty sending unit.
The thermostat issue can happen when a thermostat sticks open causing the engine to never warm.
If you change your 160F thermostat out to a 195 degree Fahrenheit thermostat, there is a good chance some part of your engine is running over the temp it was engineered for. (most likely the upper head)
/ What is Kioti thinking? #16
http://s1052.photobucket.com/user/Anthony_Lay/media/Temp.jpg.html
Thanks. That is very useful.
/ What is Kioti thinking? #17
Interesting. My 2006 DK45S also has a 160 degree thermostat, according to the service manual. The fact that the indicated temp climbs (quickly or slowly depending on load) to the bottom dot and stays there (regardless of load or air temp) makes me think the cooling system has plenty of cooling capacity. In my experience with Diesel cars, a 180-195 degree thermostat would be more typical but those car engines are seldom subjected to continuous high power loads.
I had a chance to give my new 180* thermostat a test run today. Removed the cardboard from radiator and spent 2 hours spinning the knives of my Caroni Tm1900 flail mower. Water temp gauge went up past the first dot, but not quite half way between the 1st and 2nd. Got to that point in less than 15 minutes, then held steady until I shut it down one hour and 45 minutes later. Oil temp reached a peak just shy of 180* after 45 minutes run time, then it too held steady. This tells me there's nothing wrong with water temp sender, and that 180* is between the two dots on the factory gauge. No harm will come to my engine, nor will its life be shortened running these temps. I've owned and operated diesels for over 42 years, made by VW, Izusu, and Kubota, all with pre combustion chamber heads, thousands of hours logged on each of them, at 180*+. Millions and millions of miles driving Cummins, Cats, And Detroits,(2 and 4 cycle),...every one ran at least 180*. All diesels run on the same principle, compress air to 1000*+, then squirt in some fuel. If Kioti designs and builds their heads so that something gives up with even 210* water flowing thru it, we are all in trouble...cuz when you shut them down, and the water quits moving, the temps go higher than that.
/ What is Kioti thinking? #19
Hill Billy Bob,
Because of the quote, and the tone of your last post, it seems you have taken exception to my post. It was not my intentions to offend you. I am just pointing out facts. The 160 thermostat is not a mistake, but was designed to be in the tractor by the people who built it. Food for thought; if your sending unit was out of calibration and was reading 20 degrees cooler than the engine's actual temp, when you raised the engine operating temp by adding a hotter thermostat, it would still be off. Good luck and God's speed.
rider7787,
Your post did not offend me, in fact you were the only one that offered an answer to my question "What is Kioti thinking?... I do however disagree with the statement that "a cool engine last longer", and the idea that a 195* stat will cause an over heated condition in any modern engine....Todays engine oils need to be higher than 160* to lubricate efficently.
I guess we just disagree on this topic...but hey...what a boring world this would be if everyone thought the same way....Bob
John Deere 1770NT Planter Drive (A65640)
John Deere 1770NT...
1996 International 8100 Fertilizer Spreader Truck, VIN # 1HSHBAHNXTH253889 (A65563)
1996 International...
John Deere 772-A Grader (A62679)
John Deere 772-A...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
Stryker 1.5 yard Slide in Spreader Box  (A62679)
Stryker 1.5 yard...
New Holland 499 MoCo (A66408)
New Holland 499...
