What ATV, side by side or UTV do you have.
   / What ATV, side by side or UTV do you have. #241
It depends on your definition of "better". It will be different. :)
The sway bar is designed to limit body lean when going fast and turning. The disadvantage is it limits suspension travel.
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=338398"/>
Since my main UTV use is off road, I disconnected the sway bar on my Ranger Electric.
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=338397"/>
Just rotated it all the way out of the way and put the rubber bushings back in place.
Don't know if it would be that easy on yours.
It doesn't limit suspension travel. It limits suspension articulation.
   / What ATV, side by side or UTV do you have. #242
Thought I would check the "suspension articulation". :D
I had to shift out of 4WD, because it tried to go up over the end of the board!
I am going to leave the sway bar disconnected. :thumbsup:
   / What ATV, side by side or UTV do you have. #243
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=338657"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=338658"/>
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=338662"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=338663"/>
Looks great! How u like the electric ranger?
   / What ATV, side by side or UTV do you have. #244
It is fantastic! :D Is was hard to get used to no engine noise, after having a diesel. During the test drive at the dealer's, I had to stop and back up to turn around, I put it in reverse and reached for the key to start it, because there was no engine noise! :laughing:
This one has a very quiet 30 hp AC motor, with amazing torque.
Got the glass windshield installed, but had to remove the center mounting clamp for the roof. It is designed for the metal roof, not the hard plastic roof that they sold us.
The bottom opens out for air flow.
   / What ATV, side by side or UTV do you have. #245
Just a quick pic of my new Honda Pioneer 700-4.....in order to get a new HONDA posted here. This is a new model....and it seats 2,3 or 4 riders in a short wheelbase. Look it up on Honda's site. Pretty slick machine IMO. I added a full roof and a glass windshield....so far. Just drove it a little tonight. Maybe more in the next few days.
   / What ATV, side by side or UTV do you have. #246
Are those the stock tires? They look a lot nicer than what my 09 BR came with. I ended up replacing the tires.
   / What ATV, side by side or UTV do you have. #247
Recently picked up this used 2006 "TS"Gator, 1270 hours, but the paint isn't worn of the skid pan! New Carlisle Field Trax tires all around, after market canopy. I've rebuilt the rear canopy frame for strength, added screen & receiver drawbar storage & will be making a front bumper/brush guard & receiver mounted winch. ~~ grnspot
Very nice machine!
   / What ATV, side by side or UTV do you have. #248
Yep, the tires are stock. The only things shown that are options are my roof and windshield......so far.
   / What ATV, side by side or UTV do you have. #249
Wow I really like that! Very nice!
Can u confirm if it has a locking rear diff?
   / What ATV, side by side or UTV do you have. #250
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=338698"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=338699"/>
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=338702"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=338703"/>
That's a slick windshield!
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
2021 CATERPILLAR 299D3 XE SKID STEER (A52709)
2021 CATERPILLAR...
2015 Chevrolet Express 4500 Shuttle Bus (A56858)
2015 Chevrolet...
2020 Case 5550 Trident (A56435)
2020 Case 5550...
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
2006 Cummins DGBB 35kW Standby Diesel Generator (A56857)
2006 Cummins DGBB...
