DK50SE HST Cab
/ DK50SE HST Cab #1
Poopdeck Pappy
Elite Member
Dallas, Texas
Kioti DK50SE Cab, Kubota BX23, Kubota BX2660, Grasshopper 729BT
Just ordered it today. Should be here in about a week. It's funny, but I feel more relief (at finally getting this decision behind me) than joy or anticipation.
I'm just ready to get to work. I've gotta get a stump grapple ordered asap. (See my "Stump Grapple" thread in the Attachments forum if you have any thoughts on the subject.)
And I've gotta decide on a shredder. Leaning towards the Rhino 172 at my dealer, but not sure yet.
For a box blade, I'm probably gonna buy a used Gannon with hydraulic scarifiers if I can talk a certain seller down to reality on his price. $1,250 sounds too high for one in decent (but not great) shape that may need two new hydraulic hoses.
/ DK50SE HST Cab #2
Congratulations on your new Kioti. They are a great machine and sure you will get lots of enjoyment with it. Don't know much about stump grapples shredder choice is a good one
/ DK50SE HST Cab #3
Welcome to the pack!
Nice machine, we want to see pics when it gets home.
/ DK50SE HST Cab #4
Congratulations on your new machine, and welcome to the pack. Hydraulic hoses are pretty cheap at this company.
Surplus Center
/ DK50SE HST Cab #5
Congratulations on your new tractor, very nice machine indeed, your tractor will handle the Rhino 172 quite easily though you may or may not need one with more than 1 1/2" cutting capacity, several good brands out there and of course Rhino makes a heavier cutter.
Out of curiosity how are you having yours equipped, rear remotes etc.?
/ DK50SE HST Cab
Thanks to all. I really appreciate all the advice and guidance I've received on this forum.
TripleR, I'm having a 2nd rear remote added, plus the tires loaded. And since I'm going to be using a grapple (once I pick one out) using one of the rear remotes, I'm having them route hydraulic hoses from one of the rear SCVs to the cross-bar on the front of the loader.
/ DK50SE HST Cab #7
Can you post pictures when you get it, I have three rear remotes as I have a Land Pride HR3584 box scraper and might try to use one of them instead of adding a third function for a grapple.
/ DK50SE HST Cab
I will be happy to post some pics when I get it. I'm interested to see how they are going to route the hoses.
On the mower, I know that Rhino sells a heavier mower, which I think is called the 272, but it is Category II only. Seems odd to me because Bush Hog sells their 296 6' mower, which is very heavy duty and has a Category I hitch. I wish my dealer sold Bush Hog, which would make it an easy decision.
/ DK50SE HST Cab #9
Thanks, I appreciate it.
Yeah kind of surprising, our L5740 is cat I or II as is our Land Pride RCR2672, kinda though most were.
/ DK50SE HST Cab #10
Congrats! I just picked up my the same tractor last Friday.
I picked up a 73" Caroni flail Saturday. Sunday I put 'em to work(I wish I coulda bailed the grass).
The flail did great on the grass as well as privet up to 2+" in diameter.
/ DK50SE HST Cab #11
Congrats and Welcome to the pack!
/ DK50SE HST Cab
Thanks Murph.
King, that flail looks like it did a great job! I'm impressed. Did the DK50 handle it ok without laboring?
/ DK50SE HST Cab #13
I know that the Gannon is used, but keep in mind that a new one is about $3500. Hoses are cheap. ;)
/ DK50SE HST Cab
Brian, that's a good point. But I can buy a brand new 1,100 pound Rhino box blade with hydraulic scarifiers for less than $2,500. It may not be quite as heavy as the Gannon, but it's a quality piece.
The Gannon is a big heavy beast, which is exactly what I want. I'm gonna go see the guy again tomorrow and see if I can talk him off the ledge on his price.
/ DK50SE HST Cab #15
Thanks Murph.
Handled it with no problem.
There was one low area where the grass was super thick that I had to slow down a bit, but for the most part I ran in medium range.
I got about an hour of privet done today before I had a valve stem knocked off. I didn't realize I had a flat(rough terrain) until the tractor acted like it was stuck. The rim cut the bead down. Now I have to wait until next week to replace a 9 hour old tire. That sucks, because the weekends are the only free time I have to work on the property.
The flail did a great job on the privet.
The big privet(multi stem and 3-4" diameter) I pushed over and then flailed it.
No after pics because I was dealing with the tire.
Put on 6 teeth this morning. I am adding 2 more(to either corner), but my drill melted.
teeth 001.jpgteeth 002.jpgteeth 003.jpgteeth 004.jpgteeth 005.jpgteeth 006.jpg
/ DK50SE HST Cab #16
Too bad .. Hate to hear about the tire.
I gashed the blazes out of one of my rears by turning too tight when pulling a sprayer. Luckily, it didn't get all the way through - but it couldn't have missed by much. That was with only about 30 hours on mine. Asking around, I found you could sometimes fix problems with inner liners and/or tubes and not always have to replace the tire.
Did you call service to your property or remove the tire yourself? I'll be curious to hear if you were able to repair or if the damage was too severe.
/ DK50SE HST Cab #17
Pulled the wheel and tire.
The wire in the inside inside bead was torn out so the bead was flimsy. Laid the tire on the ground and stood on it, spun the wheel 90 degrees and yanked that puppy out. The tire is shot.
/ DK50SE HST Cab #18
The wire in the inside bead was torn out so the bead was flimsy. Laid the tire on the ground and stood on it, spun the wheel 90 degrees and yanked that puppy out. The tire is shot.
/ DK50SE HST Cab #19
Are the tire valves on the inside where they are more protected? While you have the tire/wheel off would be a good time to weld a valve stem protector on the wheel. Although this does sound like just bad luck it wouldn't be hard to add the protection and a good idea if you are going to be doing lots of brush work.
/ DK50SE HST Cab #20
If it is stock Kioti there should be valve protectors on there.
Hurricane Power X3 Walk-Behind Debris Blower (A61572)
Hurricane Power X3...
PALLET OF MISC PARTS (A63291)
PALLET OF MISC...
(2) UNUSED 14X17.5 TIRES W/ 8 LUG RIMS (A64280)
(2) UNUSED 14X17.5...
1999 Sea Ray Boat w/ 2015 Shorelander T/A Boat Trailer (A61574)
1999 Sea Ray Boat...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
Ford 5610 (A64119)
Ford 5610 (A64119)
