Quick hitch top hook clearance issues
   / Quick hitch top hook clearance issues #31
I have found on some implements you can loosen the bolt that holds the toplink bushing and pry the bushing forward and retighten it and it is enough to get the QH to work.
   / Quick hitch top hook clearance issues #32
Another way that I found out this weekend is to remove the bolt and spacer at the top link (or the equipment) and cut a new spacer one that is long enough that the space at the top link is wide enough for the quick hitch hook and bolts to clear the sides. Now that may not work on all equipment but it should work on most, I am still going to get the steel and extend my hook because it will give a larger margin of error when backing up but it is an option.
I have found on some implements you can loosen the bolt that holds the top-link bushing and pry the bushing forward and re-tighten it and it is enough to get the QH to work.
I removed the bushing off my King Kutter box blade (or was it it the Land Pride blade, I forget now) & tried putting it in the quick hitch hook while not attached... It didn't fit. Hit the bushing with a belt sander a bit, still didn't fit. Took the grinder to the hook, removed the paint & maybe 1mm of metal, if that & things fit properly. I realized that it would be easier to make sure the hook would fit every attachment rather than making every attachment fit the hook.
   / Quick hitch top hook clearance issues #34
Finally got my quick hitch yesterday (Ended up getting the NorTrack from Northern Tool) & I'm having some issues. My Land Pride blade & King Kutter box blade are both advertised as being quick hitch compatible (Land Pride even has a quick hitch sticker just below the top pin), but won't quite hook up on the top, bottom attaches fine with the bushings installed. The top hook doesn't seem to stick out far enough. The bolts that attach the hook to the rest of the frame jam up against the vertical braces on the implements. Somebody elsewhere on here mentioned swapping the bolts for some pins, which gives me a tiny bit of extra room without the bolt head or nut in the way (and adjustment convenience).
I attached a photo of the box blade, where you can see the pin on the implement not going all the way down & the implement frame is pushing on the pins that hold the hook to the rest of the quick hitch. The Land Pride blade does the same thing & the top of the hook & the back of the mounting post leans over the top of the pin & the hook runs into the underside.
What's going to be the best fix? Welding a bar onto the back of the hook & moving the 2 holes backwards (like in this thread)? Or would it be a good idea to grind out the inside on the back of the hook directly where the pin is currently resting in the attached picture?
I've seen a photo or 2 with only 1 bolt holding the hook to the hitch. Is that going to be beefy enough? Would that even let the hook properly grab the pin on the implements?
as much meat as that hook has on the implement side you could probably take a saw and remove a 3/8" slice out of the slot and still have all the strenth you need. If its too sloppy weld a piece of strap on the tractor side. The last HF hitch i bought i had to recut the slot and weld in a shim because the slot was wedge shaped and the pin wouldn't slide up and down. I wish I had moved my slot outward when i was doing the repair but didn't realise I needed too until I ran into the same issue your having.
   / Quick hitch top hook clearance issues #35
took my own advice and reworked my HF top hook,sliced out a little on the implement side and added a filler on the tractor side. Net gain was +~- 3/8" which was all any of my attachments needed.
   / Quick hitch top hook clearance issues #36
I can't find the original thread where I posted my fix for the same bolt clearance problem with the HF Quick Hitch (or potentially any other with the same bolted hook configuration). but here are the pictures again. I replaced the bolts with flush pins and I think the pictures are self explanatory. It's cheap, quick, and I've been using mine this way for several years with no problems.
View attachment 337736 View attachment 337737
I know this is old, but what size pin? 1/2"????
   / Quick hitch top hook clearance issues #38
The pin size is the same as the diameter of the bolt you are replacing.
Well duh....:duh:
So on mine anyway, it was a metric bolt, best I could figure. 12MM, I'd have to say.
I got some 1/2" pins from agrisupply (cheap pins, expensive shipping) along with some bushings to have on hand.
I had to drill out the holes on the flanges on the QH, but not the ones on the hook itself. A die grinder would have worked better had I had the right stone.. Regardless, after much much grinding, it's in there and done. Pretty reasonable fix, I think. Worth noting that I did NOT extend the hook. Might have to one day, but I doubt it. My land plane clears the flanges no problem, just wouldn't clear the bolt heads.
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A50854)
2013 XLR...
2007 TROXELL KILL/TRANSPORT TRAILER (A50854)
2007 TROXELL...
2022 ISUZU NQR 18FT FLATBED (A51222)
2022 ISUZU NQR...
(3) VACUUM PUMP TANKS (A50854)
(3) VACUUM PUMP...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2019 Allmand...
2014 Ford F-150 Pickup Truck (A49461)
2014 Ford F-150...
