BX backhoe fit any larger compacts?
/ BX backhoe fit any larger compacts? #1
Sodo
Elite Member
Cascade Mtns of WA state
Kubota B-series & Mini Excavator
Does anyone know if there is a little bit larger Kubota compact tractor that will accept the BX backhoe?
/ BX backhoe fit any larger compacts? #2
good question. Not that I know of. the subframe seems too different to fit anything else.
The lack of discussion of it, (how to lengthen the stabilizers, gpm etc etc etc.) suggested that it's not being done. Thanks for the answer radioman!
/ BX backhoe fit any larger compacts? #4
Guess I gotta ask - why would you want or be looking to put a BX BH on a larger machine? Thinking about upgrading and bringing your BH with you?
Yes Chris that's the reason. Need a bigger tractor but don't have much more space in the shed....
The BX has ~460 lbs lifting at the FEL. I'd like to use it to put snowmobiles on a shelf (up/down) for example. Also to load logs onto a sawmill. It's almost enough for what I do but not quite. I'd like 1.5times or 2x the lifting power.
/ BX backhoe fit any larger compacts? #6
I've seen a post somewhere where a bx hoe was put on a different tractor if your a good fabricator I'm sure u could do it on the other hand you'll get more for the bx if u sell with the hoe gonna take a lot bigger machine to lift a snow machine up on a shelf with forks
Don't wanna do any fabrication except maybe extend the stabilizers. Looks like it aint gonna work.
Escavador,,,,,,you might be surprised...that I tested the BX24 to see how high it will lift a snowmobile on the brushfork; and it stalls at 4 feet high. Not high enough because I want to put my shelf at 5 1/2 or 6 feet high.
/ BX backhoe fit any larger compacts? #8
My bx23 would barely budge my formula z but that was a heavy liquid cooled sled
Fabrication would be having a place for the hoe to sit on and for the hooks to hook to your right not worth it
/ BX backhoe fit any larger compacts? #9
Have you checked your hydraulic system pressure? Adjusting it to the top of the range might get you the extra height.
/ BX backhoe fit any larger compacts? #10
What about a hoist? Any chance of mounting one to the ceiling? And I agree you should check your relief valve setting. Could even tweak it a little and go above max spec' pressure (about 1800 psi IIRC) and see what that does for you.
Hoist would work for the snowmobiles, but there are other reasons I need a little bigger tractor. And my other sled is probably 150 lbs heavier.
Will look into relief valve adjustment, Agreed - I'd like to be sure its set at the top of the range.
/ BX backhoe fit any larger compacts? #12
The only way you can move BH from tractor to tractor is to buy the 3 pt version like from woods brand.
Thank you, this is the info that I needed.
Kinda thinking of a B7800 with FEL & BH, any comments on that model?
New/Unused 2 Post Car Lift (A61166)
New/Unused 2 Post...
2018 Seadoo Jet Ski (A61166)
2018 Seadoo Jet...
2023 John Deere 8R 370 Tractor (A63109)
2023 John Deere 8R...
2025 JMR 4x8 Forklift Safety Basket (A61567)
2025 JMR 4x8...
UNUSED CFG INDUSTRIAL MX12RX MINI SKID STEER (A62130)
UNUSED CFG...
2020 POLARIS SPORTSMAN HIGHLIFTER XP-1000EFI ATV (A62131)
2020 POLARIS...
