1952 Ford 8N won't start
/ 1952 Ford 8N won't start #61
I have a 1952 8n ford I put a new starter solenoid on it but still want start solenoid just clicks.
/ 1952 Ford 8N won't start #62
How many volts are in the battery?
Are the cables clean?
Are the cables tight?
/ 1952 Ford 8N won't start #63
I charged the battery up it is old I may need a new. One and I'm going to get new cables for it
/ 1952 Ford 8N won't start #64
After battery is charged - wait a day after disconnected to charger. did it discharge? how the acid water level and clarity look when covers are off ? (dont forget your safety glasses) . If the battery has 12 volts and holding - then check the starter. try knocking it with a stick, sometimes the brushes doesnt want to make a connection.
/ 1952 Ford 8N won't start #66
load test the bat, and do a voltage drop test on it when starting.
Landhonor 3-Ton 3-Bag Air Jack (A66408)
Landhonor 3-Ton...
John Deere 7000 6R Planter (A66285)
John Deere 7000 6R...
2011 GALYEAN 130BBL (A65643)
2011 GALYEAN...
2008 Lincoln MKX SUV (A64557)
2008 Lincoln MKX...
2012 WESTERN STAR  4900 SF (INOPERABLE) (A65643)
2012 WESTERN STAR...
2016 Freightliner 108SD 26Yd. Side Loader Garbage Truck (A64194)
2016 Freightliner...
