B2920 50 hour service
/ B2920 50 hour service #1
jhoward
NY
Kubota B series
Had a great summer with my new B2920. Thanks again for all the help leading up to my decision to purchase a new tractor.
Just about ready to do 50 hour service a couple of quick questions
1. I am going to use Kubota 10w30 oil but in the future can I use any high quality 10w30? what about synthetic?
2. How do you change HST filter without changing fluid?
3. Any tips for winter operation? DO i need a diesel additive?
Thanks again
/ B2920 50 hour service #2
Thanks again
1.Synthectic oil is fine.
2.Use a Shop vac on your fill port.
3. I use Power Service.
/ B2920 50 hour service #3
If you do only what the books recommends ya don't lose much fluid. However, if you do both fluid filters, as I did, be prepared to replace at least a quart or more of UDT depending on how quick you are. Do a search, as there is plenty of info on the 50 hr cycle that will answer most questions.
/ B2920 50 hour service #4
1. I use Rottella T6 5w40
2. Complete replacement of UDT and filters was done @ 50 hrs.
3. Using power service.
/ B2920 50 hour service #5
I just followed the Kubota recommendations at 50 hours.....also use Power Service winter and summer and Kubota 10W-30 for the oil in the winter and summer it works okay in this climate...as recommended in the OE Manual.
/ B2920 50 hour service #6
A shop vac on the filler and you won't lose a drop except whats in the filter.
/ B2920 50 hour service #7
. Any tips for winter operation? DO i need a diesel additive? Thanks again
I always use an additive. You only have to experience fuel gelling once to convince you that you don't EVER want that to happen again. It took me 3 days to get things thawed out enough to get the tractor running again.
Sent from my iPad using TractorByNet
/ B2920 50 hour service #8
Agree with rbarker, I always use fuel additive year round and have not had any problems so far. Also, by switching to synthetic your engine will sound much quieter in cold weather.
/ B2920 50 hour service #9
The shop vac is at the hyd fill hole.
I use Kubota oil and filters from dealer and change oil, oil filter and hyd filter only at the 50 hours just like the current owners manual says.
Thanks for the advice everybody...filters on order from messicks will probably do service this weekend.
