what type of hydraulic fluid is used in a Ford 3930 and where do you put it in
   / what type of hydraulic fluid is used in a Ford 3930 and where do you put it in #1
pfuller3124
Midlothian,Va
1994 Ford 3930
what type of hydraulic fluid is used in a 1994 Ford 3930 and where do you put it in
   / what type of hydraulic fluid is used in a Ford 3930 and where do you put it in #2
it should take a UTF fluid meeting M2C134D specs... and likely good for hyds, diffy, trans, power steering.. etc.
where to add? can't help ya. RickB, maybee whodat or Ultradog will be more familiar with those brand spankin new machines.
   / what type of hydraulic fluid is used in a Ford 3930 and where do you put it in #3
Transmission, power steering, and rear axle/hydraulic system are all separate drains & fills. Dipstick & fillcap on the transmission top. Dipstick for the hydraulics/rear axle just in front of the left rear axle housing with fill cap on top of rear axle center section. power steering fill cap on reservoir, fill till it runs out.
   / what type of hydraulic fluid is used in a Ford 3930 and where do you put it in #4
Welcome to TractorByNet!
I moved your thread to the Hydraulics forum. :)
   / what type of hydraulic fluid is used in a Ford 3930 and where do you put it in #5
Hey RickB: Thank you for providing the information above for hydraulic refills. Any insight on where the drain plugs are for the 3 separate compartments? Appreciate any help, thanks!
Land Honor Skid Steer Utility Hitch Adapter (A50515)
Land Honor Skid...
2019 TAKEUCHI TL8 SKID STEER (A51242)
2019 TAKEUCHI TL8...
2015 F-550 Bucket Truck. (A52128)
2015 F-550 Bucket...
HEAVY DUTY QUICK ATTACH PALLET FORKS W/ 48" FORKS (A51244)
HEAVY DUTY QUICK...
UNUSED CFG Industrial XZ20R Mini Excavator (A47384)
UNUSED CFG...
Land Honor Skid Steer Bale Spears (A50515)
Land Honor Skid...
