what type of hydraulic fluid is used in a Ford 3930 and where do you put it in
   / what type of hydraulic fluid is used in a Ford 3930 and where do you put it in #1
pfuller3124
Midlothian,Va
1994 Ford 3930
what type of hydraulic fluid is used in a 1994 Ford 3930 and where do you put it in
   / what type of hydraulic fluid is used in a Ford 3930 and where do you put it in #2
it should take a UTF fluid meeting M2C134D specs... and likely good for hyds, diffy, trans, power steering.. etc.
where to add? can't help ya. RickB, maybee whodat or Ultradog will be more familiar with those brand spankin new machines.
   / what type of hydraulic fluid is used in a Ford 3930 and where do you put it in #3
Transmission, power steering, and rear axle/hydraulic system are all separate drains & fills. Dipstick & fillcap on the transmission top. Dipstick for the hydraulics/rear axle just in front of the left rear axle housing with fill cap on top of rear axle center section. power steering fill cap on reservoir, fill till it runs out.
   / what type of hydraulic fluid is used in a Ford 3930 and where do you put it in #4
Welcome to TractorByNet!
I moved your thread to the Hydraulics forum. :)
   / what type of hydraulic fluid is used in a Ford 3930 and where do you put it in #5
Hey RickB: Thank you for providing the information above for hydraulic refills. Any insight on where the drain plugs are for the 3 separate compartments? Appreciate any help, thanks!
2018 infintit Q50 (A50324)
2018 infintit Q50...
New Wolverine Skidloader Sickle Bar Mower (A50774)
New Wolverine...
UNUSED CFG Industrial MX15RX Mini Excavator (A47384)
UNUSED CFG...
2013 LONE STAR TRAILER MFG. (A50854)
2013 LONE STAR...
Category 3 Quick Hitch (A50514)
Category 3 Quick...
UNUSED CFG Industrial MX50R Mini Excavator (A47384)
UNUSED CFG...
