Traction Diff lock oil seal (on diff carrier plate) for MF65 Mk2
   / Diff lock oil seal (on diff carrier plate) for MF65 Mk2 #1
oilystairs
Member
Faget Abbatial, France
MF65 Mk2
Hi,
i am re-furbing my brakes at the moment and also i managed to free up my diff lock that was ceased badly. I have all the 3 oil seals but cannot find an oil seal for where the diff lock bar goes through the carrier plate. Can anyone tell me where to source one of the part number so i can google it.
Thanks, Oilystairs
   / Diff lock oil seal (on diff carrier plate) for MF65 Mk2 #2
Hi,
Thanks, Oilystairs
agco #831575m1 Its a 7/8 x 1 1/4 x 3/16 inches seal I assume its in a large disc that covers the housing. is this the correct location where the engagement shaft goes through the disc into the differential housing that operates the shift fork.
Thanks Namyessam - that is the seal i was talking about. I am struggling to find this part in europe - the seal seems in good condition (no splits or damage) and the seal is on the top side of the diff carrier plate so i wonder if i can get away with not replacing it?
   / Diff lock oil seal (on diff carrier plate) for MF65 Mk2 #4
Do you have a bearing and seal distributor in your area. Can you just replace the seal by the dimensions that I mentioned in the previous post? I imagine a supplier can match it up if you can show them the seal by outside diameter, inside diameter, and width. Its probably just a single lip seal.
namyessam
John Deere D110 42in Riding Mower (A49461)
John Deere D110...
2017 DITCH WITCH RT30 (A51243)
2017 DITCH WITCH...
F-800 POWER PUMP 800 HP TRIPLEX MUD PUMP POWERED BY 3412 CAT ENGINE (A50854)
F-800 POWER PUMP...
2014 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2014 GENIE...
2015 F-550 Bucket Truck Gas Engine (A51039)
2015 F-550 Bucket...
1999 Ford F450 Dump / Plow Truck (A50514)
1999 Ford F450...
