Traction Diff lock oil seal (on diff carrier plate) for MF65 Mk2
   / Diff lock oil seal (on diff carrier plate) for MF65 Mk2 #1
oilystairs
Member
Faget Abbatial, France
MF65 Mk2
Hi,
i am re-furbing my brakes at the moment and also i managed to free up my diff lock that was ceased badly. I have all the 3 oil seals but cannot find an oil seal for where the diff lock bar goes through the carrier plate. Can anyone tell me where to source one of the part number so i can google it.
Thanks, Oilystairs
   / Diff lock oil seal (on diff carrier plate) for MF65 Mk2 #2
Hi,
Thanks, Oilystairs
agco #831575m1 Its a 7/8 x 1 1/4 x 3/16 inches seal I assume its in a large disc that covers the housing. is this the correct location where the engagement shaft goes through the disc into the differential housing that operates the shift fork.
Thanks Namyessam - that is the seal i was talking about. I am struggling to find this part in europe - the seal seems in good condition (no splits or damage) and the seal is on the top side of the diff carrier plate so i wonder if i can get away with not replacing it?
   / Diff lock oil seal (on diff carrier plate) for MF65 Mk2 #4
Do you have a bearing and seal distributor in your area. Can you just replace the seal by the dimensions that I mentioned in the previous post? I imagine a supplier can match it up if you can show them the seal by outside diameter, inside diameter, and width. Its probably just a single lip seal.
namyessam
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
2015 KENWORTH T800 MID-ROOF SLEEPER (INOPERABLE) (A50854)
2015 KENWORTH T800...
2017 John Deere 855D 4x4 Gator Utility Cart (A50322)
2017 John Deere...
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
2006 CHEVROLET EXPRESS SERVICE VAN (A51219)
2006 CHEVROLET...
1266 (A50490)
1266 (A50490)
