PROJECT: Building a grapple bucket for the LS
   / PROJECT: Building a grapple bucket for the LS #1
TSO
Elite Member
SouthEast Michigan
Massey 1652 HST Cab
Been wanting a grapple for awhile, but ended up spending the money on other things :mad: ... oh well. So, recently, I found this new 60" Rock bucket on a local auction site, and won it for $228. :thumbsup: I figured I'd either sell it for a profit OR make a grapple out of it. Well, I wen't with option 2, so here's the project so far:
The bucket:
The metal: I picked up all the metal needed for less than $100 from my local metal shop (using scraps & cut-off's like always :D ) The lid/tines are 3/8" thickness steel X 5" width. I cut them to shape and welded them into the proper angle. Added some biting-teeth to them as well.
The lid is attached to the bucket with two 3/4" bolts at the pivots. The top of that bucket is 3" tube steel, so it's a good strong base to mount things, although I used some 3"x3" angle iron as the pivot mounts. The lid opens to around 36".
This is the progress so far, but it's only been a couple days so it's moving pretty quickly I suppose. Next step is to fab up the cylinder mounts, and add some more bracing & a center half-tooth to the lid.
QUESTION for the guys that have already used their hydraulic remotes, as I haven't looked at mine yet: What size & style connectors did you use to connect to the factory remotes? How much hose is needed to run up to the front from the rear remotes?
   / PROJECT: Building a grapple bucket for the LS #2
That was a great purchace, adding a grapple will be very handy, I wish, I had one.
Dave
   / PROJECT: Building a grapple bucket for the LS #3
I wish I had one, too. The rock bucket gave you a good platform to hang the lid on,
   / PROJECT: Building a grapple bucket for the LS #4
I have been using the 'standard' connector available from TSC for my implements.
At the front for my Third Function connections, I used the same size as what the loader uses from the factory. (Where you take it off)
Hope this helps...
   / PROJECT: Building a grapple bucket for the LS #5
Local auction site? I could use a rock bucket at that price!
   / PROJECT: Building a grapple bucket for the LS #6
1/2 inch Pioneer Ag connectors
Well fellas last night I ordered a cylinder, it's 2.5" bore, 8" stroke, non ASAE, 2500psi, straight column load rating around 12500lbs. Should do the trick, now it just needs to get here. Luckily I have all the dimensions needed for the pin spacing so I should b able to fab up everything before it gets here.
QUESTION: is 3/8" hydraulic line Ok? They have 4000psi line in long lengths at my local store.
More progress:
   / PROJECT: Building a grapple bucket for the LS #9
Should be plenty. Pretty sure thats all mine has on it, and its almost too fast as it is!
   / PROJECT: Building a grapple bucket for the LS #10
Looks good, it might be a good idea to plate the joint on the sides with a dimond or triangle plate. This area will take alot of stress.
Dave
Massey Ferguson 92” PTO-driven rear-mount snowblower
Massey Ferguson...
2016 Toro Workman HD-X 4WD Diesel Utility Cart (A59228)
2016 Toro Workman...
2025 40ft 10-Door Shipping Container (A59228)
2025 40ft 10-Door...
AUCTION STARTS HERE @ 9AM (A60429)
AUCTION STARTS...
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
CASE TV370B SKID STEER (A52706)
CASE TV370B SKID...
